how does oil get into the airbox
Old May 22, 2002 | 02:11 AM
EugeneChoe's Avatar
how does oil get into the air box. also i get blue smoke at startup always have for the past year and a half. could the smoke be from that oil. thanks
eugene
also my car wont go ito reverse.?? ouch man
Old May 22, 2002 | 02:38 AM
rx7even's Avatar
The BOV will occasionally let a little oil through, which would shoot it right into the airbox. Totally normal.
Old May 22, 2002 | 12:30 PM
maxpesce's Avatar
Ex fd *****
The Oil in the AirBox comes from The TURBOS thru either the CRV or The BOV oil gets into the Turbo Compressors by leaking past the bearings - also under boost the PCV sustem vents into the Primary Turbo inlet and can be another source of oil in the intake and/or Airbox
Old May 22, 2002 | 12:50 PM
SilvioRX7's Avatar
If your car won't go into reverse, check your shifter bushings. My car did the same thing and it was the bushings. If thats the case, pretty soon it won't go into any gear.
hope the info helps
Old May 22, 2002 | 12:55 PM
7-sins's Avatar
thats not paint....
Your turbos are probably leaking a little oil. That is why you get the blue smoke and the blow by out of your airbox. It is comming from the Charge Relief Valve or the Air Bypass Valve, totaly normal just shows your turbos are aging.
Eugene we are going to Capital Raceway in Crofton Saturday @ noon if you feel like joining, we should have about 10-15 7's. Here is the thread:
https://www.rx7club.com/forum/showth...threadid=74711
Old May 22, 2002 | 12:58 PM
ThirdGenRX7's Avatar
Waiting
so why did 3 people respond and say the exact same thing?
Old May 22, 2002 | 01:10 PM
Cetchup's Avatar
The Cursed FD
why did u respond at all?
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
