Non Seq. Dyno Sheet
Old May 21, 2002 | 07:08 PM
neevosh's Avatar
The Dude Abides
Non Seq. Dyno Sheet
With all the interest in going non-sequential lately, I thought it'd be good to show what the power curve looks like. Here's mine. Mods are CB, DP, intake, FMIC, and AVC-R, set at 10psi. Done in 3rd gear.
Old May 21, 2002 | 07:35 PM
jspecracer7's Avatar
1JZ powered
Re: Non Seq. Dyno Sheet
Sweet...Now someone post what a sequential looks like...
Old May 21, 2002 | 07:42 PM
Red Rotary Rocket's Avatar
Exclamation
Am I reading your chart incorrectly, or was your A/F higher than 13.0 in the low RPMs?
Old May 21, 2002 | 07:45 PM
nocab72's Avatar
03 Cobra Killer
jpecracer7 - just for you.
http://flathat.woodstream.net/RX7/Dyno/P4210120.JPG
K
Old May 21, 2002 | 09:18 PM
1JZ powered
K
What mods are on that car? I'm wondering if my FD's dyno would look like with a car w/ similar mods
Old May 21, 2002 | 09:22 PM
nocab72's Avatar
03 Cobra Killer
jpecracer7 - those dynos were with the following performance mods on a 94 touring, original engine & turbos, 34k miles.
Apexi Power Intake
M2 Downpipe
SS Midpipe
Greddy Power Extreme Exhaust
HKS Twin Power
Denso Fuel Pump
PFC w/commander - basemod map minus a bit of fuel.
more details & dyno graphs in my recent thread here:
https://www.rx7club.com/forum/showth...threadid=72588
K
Old May 21, 2002 | 10:57 PM
kwikrx7's Avatar
Definitely much smoother than a sequential car. Wonder why the dip in power though in the 5-6K area? Nice numbers for stock boost and your mods.
Old May 22, 2002 | 01:18 AM
1JZ powered
Apexi Power Intake
M2 Downpipe
SS Midpipe
HKS Twin Power
Denso Fuel Pump
K
We have the same mods except that I don't have the HKS twin power. My map has been running fine(slightly rich however), so I may try your map out. I'll just use your map from the previous thread since I already have datalogit. Thanks!
Old May 22, 2002 | 02:05 AM
Dr Wankel's Avatar
Altitude SUCKS!!!
Re: Re: Non Seq. Dyno Sheet
Here is mine
Old May 22, 2002 | 10:26 AM
nocab72's Avatar
03 Cobra Killer
My next project is to tweak some more of that dip out by adjusting pre-control, etc with the datalogit. I'll post my successes/failures as I play with it to help the rest of you out!
dr. wankel - a HKS twinpower will eliminate most of that upper RPM breakup and pick you up a few more HP. It is a 5 minute install, yet a bit pricy. You can FEEL how much smoother it is, I hit rev limit (8100rpm) a few times the first week after I installed it because it felt so much smoother I didn't think I was rev'ing so high.
http://flathat.woodstream.net/RX7/Dy...o-runs-3-6.jpg (before HKS, w/high flow cat)
http://flathat.woodstream.net/RX7/Dyno/P4210121.JPG
(with HKS, replaced high-flow cat with midpipe)
These two dynos were taking 3 days apart (as you can see from the dates). The only differences between the two days on my car are as indicated above. Mods were as I stated earlier in this thread, not what are in my sig now.
K
Old May 22, 2002 | 11:33 AM
ttpowerd's Avatar
HARRRRRRRRR
Dr. Wankel, how the heck did you get those numbers with the mods you have? What amount of boost were you pushing?
I have dp, hi flow cat, cb, intake, ecu and only got 288rwhp @ 12psi.
Old May 22, 2002 | 11:42 AM
Kahren's Avatar
i am not a girl
how about a stock dyno sheet, or maybe just a catback and intake and not upgraded ecu and MP
thank u
Old May 22, 2002 | 11:50 AM
MDoMe7's Avatar
flipaholic
What other information can you get out of a dyno run aside from the hp/torque curves(if any)? As you can tell I've never done one before.
Old May 22, 2002 | 01:00 PM
nocab72's Avatar
03 Cobra Killer
MDoMe7 - If the dyno you use has a wideband O2, the most valuable part of a dyno is your air:fuel ratio.
On this Dyno sheet, you'll see the a/f ratio on the bottom graph.
a/f is VERY important - run too rich you loose power, run too lean you POP your engine.
K
Old May 22, 2002 | 03:37 PM
cabaynes's Avatar
Old and grumpy
what is the advantage of running non-seq. versus the stock seq. turbo set-up? please explain...
Old May 22, 2002 | 04:51 PM
nocab72's Avatar
03 Cobra Killer
there are loads of threads on non-seq vs sequential...
S-E-A-R-C-H
k
ls1swap
Jun 3, 2024 03:25 PM
Rotate86
May 18, 2018 02:44 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
