s4 with flood problems
Old Jan 22, 2009 | 02:42 PM
derek vaughn's Avatar
I have a start up flood problem but when i get the car to run its seems to run stong once the flood clears. i have quiet a few mods but the problem came about when i installed all the smog block offs. I have an aeromotive regulator set at 60 psi set to a 1:1 boost to pressure gain and 550 primary injectors and 720cc secondarys.
Old Jan 22, 2009 | 11:10 PM
Icemark's Avatar
what are you using to control the bigger injectors?
If you just cranked up the fuel pressure and the injector capacity but didn't modify or change the ECU, it will run richer than it comes from the factory (which is already big rich) and you will probably loose power.
Old Jan 29, 2009 | 02:22 PM
ok
i have fcon wich sucks i think. for ems but i kinda need rich because i am runnin a t4 t5 hybrid turbo. the flooding is driving me crazy because every thing on the engine checks out. compression fuel pressure hold ect.. i was wondering if my inital psi at the fuel rail was set way to high or some thing dumb like that??
tidanb0utch
11
Oct 7, 2015 07:36 AM
FbFuninthesun
Oct 6, 2015 08:03 AM
PinkRacer
43
Oct 1, 2015 09:13 AM
Monsterbox
Sep 11, 2015 03:29 PM
