spinning freely
Old Jan 20, 2009 | 04:48 AM
GST7's Avatar
STANCE IS THE KEY
CA spinning freely
my car wont start and it sounds like the motor is spinning freely
wat could it be????
is this motor done
Old Jan 20, 2009 | 09:26 AM
Aaron Cake's Avatar
Engine, Not Motor
Could just be flooded.
To see if it's blown, see http://www.aaroncake.net/rx-7/blown.htm
Old Jan 21, 2009 | 11:59 PM
Could be the starter motor spinning but not turning the flywheel or broken teeth on the flywheel. Can you actually tell if the motor is turning?
Old Jan 23, 2009 | 05:19 PM
GST7's Avatar
STANCE IS THE KEY
well i took out the bottom spark plugs and it dose fire....
but just wont start
Old Jan 23, 2009 | 05:35 PM
Jase86's Avatar
if it sounds like it should start but just wont then check your flywheel if you've been bump startin then it went out then you wore out the teeth of it
Old Jan 23, 2009 | 06:58 PM
Hit Redline's Avatar
Does it sound like this?
https://www.rx7club.com/1st-generation-specific-1979-1985-18/engine-died-freeway-wont-start-video-included-753395/
Old Jan 24, 2009 | 05:21 AM
GST7's Avatar
STANCE IS THE KEY
yes it sounds just like it
Old Jan 24, 2009 | 01:56 PM
^^^ Then you know its time to call the Rotary Shack for a rebuild.
Old Jan 24, 2009 | 03:14 PM
trochoid's Avatar
Old Fart Young at Heart
If your engine sounds like the vid Hit Redline posted, then the solenoid isn't engaging the starter drive to the flywheel. Before you pull the starter for testing, run the ghetto compression test Aaron describes. In my sig line is a link to the online FSMs. Download and start reading, good luck.
Old Jan 24, 2009 | 07:51 PM
GST7's Avatar
STANCE IS THE KEY
ok thanks for the help fellas....
ill post my updates and tell you
guys how every thing go's..
LongDuck
Oct 7, 2015 08:12 PM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
c0rpse
16
Sep 25, 2015 11:33 AM
Enzo1944
Sep 6, 2015 08:57 AM
