cat converter
Old Jan 10, 2009 | 04:18 PM
my1st7's Avatar
cat converter
What do you do with the hose that hooks to the tube that goes to the cat,after you remove the cat? It is a 82 fb.
Old Jan 10, 2009 | 09:25 PM
mar3's Avatar
Administrator
You removed the cat? What happened to the air pump? Air is pumped to the cat via that tube, so it depends on whether the air pump is functioning still. If not, yank the tube and cap the part of the manifold where it attached to. If you've still got the air pump working, just get another 3-way cat and return the system back to stock cleaning ability. Rotaries are horrific HC spewers without that system.
Mario III
ls1swap
Jun 3, 2024 03:25 PM
Andrew7dg
Aug 6, 2017 01:41 PM
lnlreaper
Sep 27, 2015 09:59 AM
