South RX-7 Forum Serving Texas, Oklahoma, Arkansas, Louisiana, Mississippi
Next great project
Old Jan 7, 2009 | 02:14 AM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
Next great project
ok as most of you know I like to push the limits on things. Well it is time to do that to the next level. As some of my closer friends know I wanted to build a drag car to do a sub 10 sec run, I was really shorting for a fc but now I am thinking rotary VW Bug.
They are so lite and with a rotary capible of high horse power output, I think it would be easy to make a sub 10 sec car.
Does anyone want to help me find a free or really cheap bug, I was even thinking vw bus
Old Jan 7, 2009 | 09:26 AM
No_love_for_pistons's Avatar
Parts collector
I've owned a few in my day. Actually was driving one when I first fell in love with the RX7.
Stay away from the bus. What you'd want is most likely a Super Beetle. I had two early 70s bugs and always thought about doing this type of project to them. Can't wait to see it!!
Old Jan 7, 2009 | 02:28 PM
Rx7_Nut13B's Avatar
What about tires and the trans-axle, what do you do about the higher hp thru and to them.
I have heard that you can use porchs trans-axle, but how much stronger are they?
I just got a line on a Super Bee.....
Old Jan 7, 2009 | 05:30 PM
Parts collector
PM sent.
You will def need to fabricate a few parts from what I understand.
Didn't someone on the forums make the conversion?? A dune buggy, I believe...?
Old Jan 7, 2009 | 05:50 PM
Rx7_Nut13B's Avatar
fabracation isn't a problem, it is getting the power thru the trans axle without breaking every thing.
Old Jan 7, 2009 | 05:52 PM
DrKillJoY's Avatar
Administrator
If your just making it to go fast why not just build a rail.
If you want to compete in a specific category that's different.
Old Jan 7, 2009 | 06:09 PM
sanchezrx-7's Avatar
Get a older import body like toyota 86 and older or mazda rwd from the same 86 and older 2door, sartet is a great shell with almost no chopping you can get in to the low 10's, vw that i heard running that kind of times require the trans from porshe to hold the high rpm's, but it can be done and good luck
Old Jan 7, 2009 | 11:49 PM
prrex4ever's Avatar
Now What?
I believe that Kennedy Adapters has a kit to adapt a rotary to a VW trans. but I guess the big ? is how much power can it hold?
Old Jan 8, 2009 | 12:38 AM
Rx7_Nut13B's Avatar
yea the trans will be the issue, I am reading that they are good to about 300 hp.
Keith the problem with building a rail is loads of piping, welding, and still having to get the power to the ground.
I have read that a 300hp bug can run 10's in the 1/4, so I can run a NA
Old Jan 8, 2009 | 12:59 AM
DrKillJoY's Avatar
Administrator
I meant buying an old rail that's ready to go... as opposed to buying a car and stripping it down and/or modifying it.
But yeah, either way. 300 hp N/A (using N2O?) or 12,000 RPM bridgeport I'm curious now?
Old Jan 8, 2009 | 02:32 AM
Rx7_Nut13B's Avatar
at first we were thinking turbo right off the bat, we are going to push the NA side first then later go turbo
P-port with weber carb = easy 300hp using no nitrous
Then we we go turbo install FDrotors and run a gt40 or gt42 for 600hp
Old Jan 8, 2009 | 09:25 AM
Parts collector
600HP? Oh dear god....Hitler is rolling in his grave...
You must post pics of this project. I'd drive from DFW to see this puppy run!
Old Jan 8, 2009 | 12:51 PM
philiptompkins's Avatar
I'm down... for me I'd make a turbo rotary convertible super beetle for a street rod. I think one thats totally stripped with no interior or top would be class.
Old Jan 8, 2009 | 02:47 PM
Gremlin's Avatar
Part-time Sancho
65 VW with 12a New Braunfels
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/FrNbMU23e9g&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/FrNbMU23e9g&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old Jan 8, 2009 | 03:10 PM
ratboy's Avatar
That 65 bug was for sale in New Braunfels back in July from a guy on one of the local reefkeeping sites. I would have considered picking it up if I hadnt just bought my REPU or as a 3rd rotary (for my wife) if it was a vert!
Old Jan 8, 2009 | 03:18 PM
Gremlin's Avatar
Part-time Sancho
The vid was posted on AlamoMotoring.com back in February. The thread has not been updated since May.
Old Jan 8, 2009 | 04:49 PM
DrKillJoY's Avatar
Administrator
HOLY EMBEDDING BATMAN!!
When did that get turned on.
Old Jan 8, 2009 | 04:57 PM
Gremlin's Avatar
Part-time Sancho
Got me bossman.
vipernicus42
Mar 7, 2016 04:57 AM
vipernicus42
Canadian Forum
Sep 5, 2015 09:37 AM
