where's my power
Old Jan 4, 2009 | 03:21 PM
jaseraserx7's Avatar
Rotor Head
Unhappy where's my power
I have been trying to fix my 86 gxl forever, i have had to replace a broken diff. mount, and got into a war with a rat over my wires. Luckily my dog killed the rat before it got near the cpu, i just took the car out for the first time in nearly 2 years and i have no power after first gear, when i give it a little gas it is making this weird kinda popping noise, it does it through all the gears after that but doesn't seem to start until i shift out of first, but once it does when i down shift back into first it does it there to. wtf happend to my car? if anyone has any ideas please let me know, i am frustrated and can't even think of where to start
Old Jan 4, 2009 | 04:16 PM
IanS's Avatar
Ricer
the popping sound is probably detonation. This is very bad for rotaries. I would make sure to recheck all things associated with timing/ignition system and also test your fuel pump for proper pressure and flow.
Old Jan 4, 2009 | 05:48 PM
Rotor Head
i took the cas out when i was checking for spark a few weeks ago, if i didn't put it back in right could that cause this to happen?
Old Jan 5, 2009 | 10:05 PM
Rotor Head
how do i know the CAS is lined up right?
Old Jan 7, 2009 | 03:14 AM
lele73's Avatar
15U24
you had a Hood Rat too huh? I had one in my Audi. Bastrd rat ate my realys
Old Jan 7, 2009 | 12:20 PM
Oni19's Avatar
Did you actually take it apart to clean/overhaul/replace??
Old Jan 7, 2009 | 04:29 PM
IanS's Avatar
Ricer
As you may know already the CAS is basically a distributor only it also tell the ecu when to fire the injectors as well as the ignition. The CAS being off a tooth can most definitely cause your problem. Check your timing with a timing light and then let us know what happens.
Old Jan 7, 2009 | 04:34 PM
Rotor Head
will do thank you
Old Feb 8, 2009 | 05:36 PM
Rotor Head
ok now my cas is in right, car seems to be in time but i still don't have even half the power the car should. everything seems normal the car drives fine but when i try to accelerate fast at all i have no get up. any ideas
rgordon1979
40
Mar 15, 2022 12:04 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
