What Ecu Is User Friendly
Old Jan 3, 2009 | 10:44 PM
ROTARY MANIAC's Avatar
Easy To Install,full Ilistrations ,manages Fuel And Ignition And Is Fully Programible To The T
Old Jan 4, 2009 | 10:18 AM
Aaron Cake's Avatar
Engine, Not Motor
If you don't have any experience in tuning, then no ECU is user friendly. How much experience do you have? Have you done any research into the ECUs listed under the Engine Management forum?
Old Jan 6, 2009 | 01:40 AM
AnthonyNYC's Avatar
Stay tuned...
Easy to install - All are about the same when it comes to installation. Things that get it more complicated is the ignition setup. Internal reluctors or MSDs, crank trigger wiring etc will all make the installation a little harder. Easiest that I have installed is the TEC3 since there are 3 wires for each of the coil packs and only 1 2wire for the trigger. Very easy install.
Most ECUs nowadays come with great illustrations/wiring diagrams. Haltechs are easier to tune for most. I like ECU's that use cells rather than bars. I also like ECUs that have all fuel/timing load settings on one page, makes tuning in my opinion much easier.
I have installed haltechs, from the E6ks to the E11, microtechs and Electromotive. I prefer the TEC unit overall but love the features of the E11.
Anthony
Old Jan 6, 2009 | 08:43 AM
silvialost's Avatar
Installation may get tricky unless you have a clude what you are doing but I am in love with autronic. I have a SM4 in my corolla and it will soon go in my fc once i have a motor for it.
Interface is awesome and the driveabiltiy is amazing.
Old Jan 6, 2009 | 11:13 AM
Pele's Avatar
Right near Malloy
+1
Firstly, theres the electronics:
You can't just go hacking up a harness and taping wires together...
You have to understand what signals are needed for what functions; crank/cam angle sensors, wideband AFR, Coolant temp, Intake air tamp, manifold air pressure, throttle position.... It all needs to go to the right place.
Then there's the tuning:
If you tell the engine to go to 17:1 AFR at very low kPa MAP and high Throttle and then you floor it, what do you think's going to happen?
If you don't know the answer to this, then you shouldn't be running an aftermarket ECU at all.
dkwasherexd
May 27, 2017 04:51 AM
mazdaverx713b
19
Aug 29, 2015 12:30 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
