874.08rwhp New number
Old Dec 26, 2008 | 06:21 PM
4sfeedit's Avatar
45 psi
Old Dec 26, 2008 | 06:47 PM
Slammedblk7's Avatar
Yes its slow
dammit.............
Old Dec 26, 2008 | 06:49 PM
joeylyrech's Avatar
87 SE WITH S5 T2 SWAP
Details?
Old Dec 26, 2008 | 06:52 PM
4sfeedit's Avatar
Originally Posted by joeylyrech
Details?
Details are on the other thread. 810hp.
Marko
Old Dec 27, 2008 | 11:28 AM
J-Rat's Avatar
Alcohol Fueled!
Congrats man!
Old Dec 27, 2008 | 11:37 AM
junito1's Avatar
F**K THE SYSTEM!!
Damn man!!.. MAke me a short block=D A lil pony keg=P
j/k
COngrats!
Old Dec 28, 2008 | 11:00 AM
ZAN_TUNING's Avatar
Just turn up the boost!
wtf! this is still on q16? you guys are really pushing that fuel hahaha
incredible numbers!!!!!!!!!!
Old Dec 28, 2008 | 01:09 PM
LaSkt9's Avatar
yota experienced mazda no
holy jesus 45 psi? solid apex seals?
Old Dec 28, 2008 | 03:48 PM
4sfeedit's Avatar
Apex seals are custom made but the factory assist piece is still factory material. I have nad no problem with factory seals, at 37psi. But the aftermarket seals are more forgiving.
Marko
Old Dec 28, 2008 | 03:51 PM
4sfeedit's Avatar
25%vp import
And we ran out of wastegate and pump.
Old Dec 28, 2008 | 03:56 PM
Stanello's Avatar
backslash beanbagrace
What's the SAE corrected number?
Old Dec 28, 2008 | 03:59 PM
kabooski's Avatar
Laying Down Rotary Law
wow !
Wierd tho how most people ErnieT,crisspeed's V8 killer and others
say they maxed out 4 1600cc injectors on Q16
V8Killer 680rwhp nearly maxed out added more injectors
ErnieT early 700's added more injectors
not too far away from 900rwhp on 4 1600cc injectors!
Man you are one the best rotary/ tuners out thats for sure
Old Dec 28, 2008 | 05:07 PM
4sfeedit's Avatar
LA
Originally Posted by kabooski
wow !
The engine build determines how much fuel is needed to make the power. A loose engine will take more fuel to make the same power. Also the pumps used to supply the injecters play a large part in the equation.
The set up is stable at 850hp and pulling it to 9300. We definately need more pump, but injecter duty had some more room.
Marko
Old Dec 28, 2008 | 05:11 PM
sk8world's Avatar
Chasing numbers
congrats.... very nice...
Old Dec 28, 2008 | 05:34 PM
4sfeedit's Avatar
I will have a look when I get to the shop tomorrow. We are at sea level. And inlet airtemps are matched to what we race with at the track. This is why we use uncorrected numbers.
Marko
Old Dec 28, 2008 | 07:21 PM
sleeper7's Avatar
What was the MS injector time at max hp?
chuck
Old Dec 28, 2008 | 07:24 PM
MOBEONER's Avatar
It's finally reliable
wow.is that on a s5 engine???
Old Dec 28, 2008 | 07:53 PM
ZAN_TUNING's Avatar
^^^ yep! haha
Old Dec 28, 2008 | 08:30 PM
Yes its slow
was the e shaft stock or aftermarket? also what all was done to the engine as far as prep for high hp
Old Dec 29, 2008 | 08:53 AM
4sfeedit's Avatar
chuck
Duty at max power was 7.5ms. I had to shut it down early as the pumps could not keep up.
Marko
Old Dec 29, 2008 | 09:08 AM
4sfeedit's Avatar
The engine was using all stock components including 9-1 comp rotors. Which have been clearanced for shaft deflection. All has been done inhouse including the dowelling.
The only aftermarket modification was the long section of a 2 piece 2mm seal. Everything else is OEM.
Marko
Old Dec 29, 2008 | 11:08 AM
T04Eneedy's Avatar
adiabaticly inefficient
Wink Damn
i eventually would like to push my 13b to roughly around this power level.just out of curiousity,does this car ever hook up on the street? cuz i picture it spinning its *** off in 4th.
also,how far did u guys push the MP GT45? did it fail or did u guys just want more power?
awsome setup,any pics?
Old Dec 29, 2008 | 11:09 AM
BDC's Avatar
BDC
BDC Motorsports
Great stuff, Marko!!
B
Old Dec 29, 2008 | 11:11 AM
BDC's Avatar
BDC
BDC Motorsports
Originally Posted by 4sfeedit
45 psi
Btw, it's time for a new camera.
B
Old Dec 29, 2008 | 03:17 PM
olyrx7's Avatar
Great Tuning Marko!! Real nice to see these results in our neck of the woods!!
