turbos.....
engine internals do not need to be changed.... assuming they are good now
this topic has been covered many times so a quick search should get you more info than you ever wanted. also, if ya need more info just yell.
What kind of 13B? If it's a 6port it's a bit more difficult for a new owner. There are numerous threads on adding a turbo to a 6port motor. Just search "turbo 6port motor" and you will get results.
Welcome to the forums.
welcome to the board.
the simple answer is no. you don't NEED to change anything internally.
the more complex answers will depend on what you're trying to accomplish - how much power, what turbo you plan to use, will it be used on the street, track, both, etc.
thanx for the info guys...im new to all things concerning rotors...lol i understand the basics like how they work but, building one...im lost. this will be my crash course. ill search the info and make some plans from there. again thanx for the info.
here this may help http://www.aaroncake.net/RX-7/naturbo.htm
Everybody was new to these engines at one time. The simple operation of them is easy, but once you start getting deeper into it, it's more difficult to understand at first. Now it's pretty simple.
Trending Topics
Copied directly from the 2nd gen FAQ.
Can I swap a Turbo engine/Jspec engine/13BT/etc into my Non Turbo?
Yes, check these links:
https://www.rx7club.com/forum/showth...threadid=26647
http://www.rotaryresurrection.com/ro...conversion.htm
What Turbo kits can I add onto my non turbo RX-7?
There are no longer kits formally made at the time of this post, however there are companies from time to time that do make available non turbo to Turbo Kits. Because most of these companies stop building the kits, or go out of business in short time, it is impossible to keep active links for them.
Most people that turbo a non turbo make their own kits:
Using the stock TII turbo, exhaust manifold with spacer, NA intakes and NA ECU:
http://www.aaroncake.net/rx-7/naturbo.htm
https://www.rx7club.com/forum/showth...threadid=88540
https://www.rx7club.com/forum/showth...threadid=88758
https://www.rx7club.com/forum/showth...hreadid=124232
http://users2.ev1.net/~ccoutts/turbo..._a_project.htm
Using the stock TII turbo, exhaust manifold, intakes, ECU:
http://forum.teamfc3s.org/showthread.php?t=37694
Turbo-NA Forum:
http://www.aaroncake.net/forum/forum...urbocharged+NA
Turbo-NA Forum:
Rotary93
50
Sep 25, 2003 03:09 PM
R Xplicit
Jun 20, 2002 05:00 PM
