Metering Oil Lines
Old May 17, 2002 | 11:46 AM
KIRKS7's Avatar
Metering Oil Lines
I'm trying to replace the gasket on the back of the water pump housing, however I cannot remove the housing because the metering oil lines are in the way. I was wanting to see if it's alright if I disconnect the lines on the front at the bottom of the engine. If you guys know of a different way I'd appreciate any info you may have.
Thanks
Kirk
Old May 17, 2002 | 11:57 AM
Keaponlaffen's Avatar
Yes, you can disconnect the OMP lines, but be VERY careful when doing so. They are brittle with age, and will usually crack or snap if too much pressure is exerted on them...
Jeff
Old May 17, 2002 | 01:06 PM
85RX7GS's Avatar
Yeah, be careful with those lines. Mine are still good off my 85 and they aren't THAT easy to break as long as you're really careful. So don't worry.
Old May 17, 2002 | 03:44 PM
RotorMotorDriver's Avatar
Seven Is Coming
The ones on my 83 are about as brittle as a drinking straw, however, the ones on my 84 snapped like uncooked spaghetti . So just be careful, and you'll be alright .
~T.J.
FD7KiD
15
Feb 26, 2021 10:12 PM
Snoopy FD
Dec 8, 2015 01:45 PM
BLK 93
Aug 19, 2015 03:47 AM
FD7KiD
Aug 17, 2015 11:50 PM
