Need wiring info coolant buzzer
Old Nov 7, 2008 | 08:37 PM
chemicool's Avatar
OK I have read and read the past posts regarding this issue. My engine was recently rebuilt and ever since the coolant buzzer goes off constantly. The sensor is new, the coolant is full. No air. I have read about a wire connector behind the power steering pump. I believe I found the wire however I have a question regarding the color of the wires. One wire is brown/ white as it says on the wiring diagram. The one mine is connected to is red/black. I think this might be the wrong wire as the diagram only shows brown/white in that circuit. Can some folks look at theirs and let me know. It's a 94
Old Nov 7, 2008 | 09:02 PM
Hm, do you have p/s? I seem to remember that it's a simple thin black wire with a large black spade connector on it. I think it can be mixed up and plugged into the p/s pump, not positive....
Old Nov 7, 2008 | 09:48 PM
chemicool's Avatar
Yes I have PS. There is also wiring going to AC compressor near there. My wires are the brown/white (matches wiring diagram) connected to red/black wire (couldn't find on wiring diagram for coolant buzzer
Old Nov 8, 2008 | 05:24 AM
Banzai-Racing's Avatar
Rotary Specialists
Actually they get mixed with the A/C connections. Make sure that you didn't mix the two black connectors (buzzer) and the two white connectors (A/C). If they are connected properly then try grounding the wire going to the low coolant sensor, if it turns off then the sensor is bad or you have low coolant.
Old Nov 8, 2008 | 08:02 AM
badddrx7's Avatar
All Spooled Up
Sounds to me like you have your coolant level signal wire that goes toward the dash plugged into the clutch on the AC compressor. Somewhere back toward the front top of your engine is a black wire single connector from the coolant switch that it is supposed to plug into. Better do some checking.
report back
later
Old Nov 8, 2008 | 08:08 AM
chemicool's Avatar
So the white connectors go together and the black connectors together. That might help. I will look into it more today. KInda hard to see down there and the wires are all pretty short.
Old Nov 8, 2008 | 09:27 PM
chemicool's Avatar
Well I fixed it. Thanks for the help guys. The builder did swap the two wires. Now no more buzzer. YAY! White to white. Black to black. Idoesn't get any easier than that.
Old Nov 9, 2008 | 09:12 AM
badddrx7's Avatar
All Spooled Up
Hell you've even got some AC working right again for you!
Later
Old Nov 9, 2008 | 06:37 PM
chemicool's Avatar
Later
Well no. My condensor and lines have to be reworked after my v mount install. But it is cooler now so no problem yet.
Old Dec 19, 2008 | 11:42 PM
ncastrignano's Avatar
RE for life
so i think im having the same issue i think but some one cut and hacked my harness so if someone could tell me the correct color wire thats supposed to go to the coolant buzzer that would be much appriciated. i dont need info on the ac wire because i dont have ac on my car. thanks.
Old Dec 19, 2008 | 11:58 PM
IRPerformance's Avatar
Sponsor
Should be a single wire with a spade type connector. If I recall its black with a red tracer but its 1am and I am exhausted. It connects between the engine harness and battery/starter/alternator harness around the power steering area. Often the connector gets stuck under the ps pump or by the oil filler neck.
Old Dec 20, 2008 | 12:16 AM
RE for life
alright ill take a look tommorrow when i have light. i hate dealing with this old crusty *** engine harness i just cringe anytime i have to move wires around hoping nothing breaks. thanks
Old Dec 20, 2008 | 12:17 AM
Sponsor
I would replace it. Youre going to have more problems down the road if you dont.
Old Dec 20, 2008 | 01:47 AM
RE for life
ya i want to but due to this bad economy i have no job so comin up with the money to get a new one is kinda out of the picture for now. and i just spent all the money i had to get the car running again and its still not running well enough yet to drive.
Old Dec 20, 2008 | 07:42 PM
chemicool's Avatar
There are only two connectors down there. Two white and two black. make sure they are matched white to white and black to black.
Just behind the PS pump and near the front plugs
Old Dec 26, 2008 | 06:23 PM
RE for life
so i looked for it yesterday and cannot seem to find this plug or wire on my harness and i kno it was there before i pulled the motor but im not sure if it broke off and went bye bye. but if someone could possibly send me a picture of were the wire comes out of the harness at that would be much appreciated. that way i kno if mine broke off. thanks
Old Dec 26, 2008 | 07:23 PM
badddrx7's Avatar
All Spooled Up
No more hand holding...You don't need a picture, just your shop manual, a piece of 14 gauge wire and solder. Go to page Z-44. See the Coolant level sensor there. Ok then run you a new wire from the sensor connector C1-07 on across the engine, and up to X-12 on the driver fender. Forget about the other wire/connector. Splice into the BR/W wire there at X-12 and you should be good to go
Wo - don't have a manual - then you are doomed to listening to a high pitched squeel of the buzzer going off forever and ever....the above instructions are so simple a caveman could do it.
Later
Old Dec 26, 2008 | 08:13 PM
RE for life
alright that seems simple. will this just shut up the buzzer or does it still allow the sensor to work like it is supposed too. thanks
Old Dec 26, 2008 | 08:27 PM
badddrx7's Avatar
All Spooled Up
Yes, This effort will effect a proper repair and restore the system as it is intended to operate. The buzzer will silence and ONLY sound out if your coolant level is below the normal level. Kodus to the Mazda team for putting in on our beloved FD.
Run the wire and report back.
Later
Old Dec 29, 2008 | 11:15 PM
RE for life
that worked. shut the buzzer up and was simple to do. hardest part was figuring out what the blurry FSM was pointing to for x-12 but they r the gray plugs that r right by the battery. thanks for all the help and saving me from headaches in the future.
Old Dec 30, 2008 | 01:20 AM
badddrx7's Avatar
All Spooled Up
Dame good job...a newbie with only 40 posts....now anyone else can fix this in the future or see this man, he'll show you how to do it.
LAter
Old Mar 19, 2009 | 04:41 PM
hwnd's Avatar
watashi no shichi
Later
worked well, thanks.
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
AXA
Sep 5, 2015 10:06 AM
