Benefit of Porting Wastegate on 88 t2
Old May 14, 2002 | 06:23 PM
wallin's Avatar
What is the benefit of porting the wastegate on my 88 turbo 2 and how would i go about doing it if I see some actual benefits
Old May 14, 2002 | 06:28 PM
NZConvertible's Avatar
I'm a boost creep...
Re: Benefit of Porting Wastegate on 88 t2
If you install a full exhaust the tiny wastegate will not be able to flow enough to control boost. Boost will skyrocket and the fuel system will not cope. The engine will lean out, detonate and die! This is not a performance mod, it's a "keep you engine in one piece" mod.
As for doing it, basically pull the turbo off and make the wategate hole bigger!
http://fc3s-pro.com/TECH/MODS/TURBO/wg.htm
Old May 14, 2002 | 06:35 PM
wallin's Avatar
thanxs just drill a bigger hole though
Shainiac
Jul 17, 2019 02:20 PM
24seven_dada
20
Nov 10, 2018 12:03 PM
Ian_D
Oct 14, 2015 12:31 PM
