Proper Compression Reading????
Old May 14, 2002 | 11:14 AM
jon mitrosky's Avatar
Question Proper Compression Reading????
What would be a good compression reading for a 93 R1 with 115000 miles on it??? Any info would be great!
Old May 14, 2002 | 11:19 AM
airborne's Avatar
King of the Duct Tape
7kgf/cm2 or 100psi is the minimum compression for the FD. i think it can be as high as 9, but shouldn't vary by more than 1.5 per side. thats straight from the manual. if its the original engine and is above minimum i'd say thats awesome for a 115k engine!
Old May 14, 2002 | 11:25 AM
i am going to get a compression test on thursday...so well see.
Old May 14, 2002 | 02:52 PM
Nathan Kwok's Avatar
The "maximum" (ie factory new spec) is 8.5kg/cm^2 according to the shop manual. Also, after '93 the manual was changed to make the minimum 6.0kg/cm^2. I personally know of people in the 6s running around just fine, although the general consensus is that the seperation between chambers is more important than the absolute numbers. Make sure you ask what units they are using, sometimes it is reported in psi, and i've heard of one case where the dealer used a 1-10 scale, which is misleading.
Old May 15, 2002 | 10:54 AM
i hope mines around 6 or 7kg then.....
ZacMan
Sep 19, 2015 09:20 PM
SCinfidel
Sep 8, 2015 05:36 PM
whinin
Sep 5, 2015 11:52 PM
