Open wastegate?
Old Oct 19, 2008 | 06:36 PM
93type-x's Avatar
RX7_pilot (ps3)
Open wastegate?
Ok heres the thing.... i got a 46mm wastegate, 0.8bar spring and Blitz boost controller, all OK ,or so I thought the wastegate seems permanently open, ... not all the way that happens as it should @ about .79,happy, its slightly open all the time and sound s**t, its on a screemer pipe but my buddy has the same setup and his is quiet until its time to get loud
I have checked the flanges and fitting and changed the spring for one the same size, no difference.
any help please its killing me
Si
Old Oct 19, 2008 | 07:00 PM
NissanConvert's Avatar
Please somebody help!!!
pictures? is there any difference between yours and your friends?
Old Oct 19, 2008 | 07:16 PM
mad_7tist's Avatar
how do you have the boost controller hooked up to it? sure the spring is the right one and is installed correctly?
Old Oct 19, 2008 | 07:22 PM
CarbonR1's Avatar
Make sure you have the wastegate ring installed too.
Old Oct 19, 2008 | 08:24 PM
93type-x's Avatar
RX7_pilot (ps3)
its th 46,,, my friend has HKS 60mm, but yes they are set up the same , the lines are correct and the boost controller is ok.
I had a flat flange on it at one point so it wasnt sealing, but now i have the one with the raised lipthat fits into the "valve"? type thing its even worse...
does this help you? doctors?
Old Oct 19, 2008 | 09:21 PM
smell of exhaust under the hood? If the flange isn't leaking then it would follow that the wastegate is defective.
Old Oct 19, 2008 | 09:49 PM
arghx's Avatar
rotorhead
sounds like you didn't install the valve seat/fire ring/whatever you wanna call it.
Old Oct 19, 2008 | 10:43 PM
93type-x's Avatar
RX7_pilot (ps3)
thanks guys ,,, looks like its back to the drawing board then ...
Old Oct 20, 2008 | 02:25 AM
rx72c's Avatar
Top Answer: 1
either bad flange or **** gate.
Go get yourself a proper gate.
IF you want a quality gate. Pm me.
Andrew7dg
Aug 6, 2017 01:41 PM
