removed dash, deleted heater core, now no radio or speedo
Old Oct 19, 2008 | 04:05 PM
Davin's Avatar
Back door, no babies...
Veteran: Navy
i removed the dash properly to delete my heater core, wiper motor with wiper arms and the rest of the A/C stuff since i dont need it anymore, now my radio or anything on the gauge cluster does not operate at all. everything was hooked up properly, all my fuses are good, and now i cannot figure out what i did wrong.
the only thing i can thing of, since i completely unclipped the AC/heater wire harness, kind of a connection that needs to be there? i also removed the Clairion box as well from the armrest, assuming it was part of the stock radio, is that important?
Old Mar 31, 2011 | 01:29 AM
WHIPSrx7's Avatar
DRFTRX7
TTT! I am removing my heat and A/C and want to make sure I don't have to keep any of the electrical connections on either the heat box or A/C box. Thanks in advance.
Old Mar 31, 2011 | 08:03 AM
evot23's Avatar
Classy
Check your ground points. There are 2 for the dash panel and 2 for the instrument panel...both sets are common grounds that run through A/C/heater wire harness.
Find your grounds and you should be able to get back to business.
Old Mar 31, 2011 | 08:05 AM
evot23's Avatar
Classy
The OP was realllly reallly old...how did you find that in the search but no solution...?
Old Mar 31, 2011 | 12:10 PM
cabaynes's Avatar
Old and grumpy
Here's some advice. Don't do it. I don't care how much you think it's going to help in terms of weight savings, it's not worth it. If you ever go sell the car it's only going to decrease its value further, and if you ever want to put it back in it's only going to create headaches. Unless you're totally stripping the car and putting a full cage in for dedicated track racing only, I'd leave it in.
Old Mar 31, 2011 | 12:12 PM
evot23's Avatar
Classy
ie...work on creating more hp vs losing weight.... and cabaynes is 100% correct, I would concur on the advice
Old Mar 31, 2011 | 03:33 PM
WHIPSrx7's Avatar
DRFTRX7
I was temporarily removing it until I get a new heater core. It isn't for performance and I'm never (Lord-willing) going to sell the car. So I could care less about the resale. That's unfortunate that you both think I should keep them in there...I was hoping to save time, which I don't have a lot of (car needs to be moved by tonight).
Old Mar 31, 2011 | 04:04 PM
muibubbles's Avatar
Bubblicious DEF.
doubt check the connectors.. there is a harness on the dash support bar that maybe you have missed? that would be my guess... i dont believe cutting the wires would effect other components unless they were tied into it (doubt it) just mt .02
Old Mar 31, 2011 | 04:36 PM
rx7rcer09's Avatar
Sir Braps A lot
like stated check the grounds, ive never removed the dash but knowing FD's there is probably a few Grounds tucked behind there. also with the radio is its stock?
Old Mar 31, 2011 | 04:47 PM
Davin's Avatar
Veteran: Navy
OMG, I posted this 2.5 years ago, lol! I have since figured it out... Thank you for all the late responses
Thor 18
Interior / Exterior / Audio
Sep 13, 2015 08:39 PM
OrangeMax
Sep 4, 2015 10:42 AM
matty
Aug 28, 2015 05:16 PM
