Differances in S-series rotors
Old Oct 14, 2008 | 03:20 PM
MAXX65's Avatar
So I've read in a few places about the difference in wieght of the rotors as the years have gone by. I know that mazada had to of progressed in the development of the 13b from 93-02, but the changes and improvements are a bit foggy from the things I have read.
The reason why I ask is because I am getting a 99 spec front clip and I am tring to find all the differences between my 94 13b and the 13b I will be getting. I know that the turbos have been upgraded, but thats really the only thing I'm sure about since I'm running 99 spec turbos on my current motor.
Please enlighten me....................Thanks
Old Oct 14, 2008 | 09:11 PM
DaleClark's Avatar
RX-7 Bad Ass
In general, the short blocks are all the same from '92-02. Rotors are the same, I think they did some upgrades on the rotor housings and oil injectors over time, though.
Also, what does "S-series" mean? Never heard that before.
The FD's motor basically kept the same short block but upgraded other things around it as the years went on. Better turbos, better ECU, black box instead of rat's nest, etc. Everything was very evolutionary.
Dale
Old Oct 15, 2008 | 03:56 PM
MAXX65's Avatar
S-series is the actual rotor. I know that the s4 rotor was used in the late 80's early 90's (not sure if it made it into the FD) and the s6 can out sometime in the mid s90'. I thought I read about a s8 rotor, but I could be mistaken. the content I read this was about the weight of the rotor changing to decrease rotating weight within the drive train.
so did the eliminate the rats nest of air lines? black box?
Old Oct 15, 2008 | 04:22 PM
Mahjik's Avatar
Mr. Links
This was posted by someone who is not here anymore:
That's right. There is, as stated above, a hardness difference between 91 and 93, the older ones required a bit more OMP lubrication, 4 oil injectors instead of 2. You wouldnt want to use one FD and one FC housing because of this difference. There is no way to lube one more than the other, and it's even slightly possible that you'd get more wear in one chamber than the other (on apex seals) because of the hardness difference.
That said, I don't think there would be any REAL WORLD problems with using one and one. Most fd's arent daily driven and most dont even make it 50k at a time on an engine. This is the kind of thing that makes a difference at 100k, but not really by 50k or less. REgardless, I would shy away from it unless it was really necessary, i.e. the car had to be on the road asap, or the owner had no money, etc. Either use 2 of one or 2 of the other. This is true of the differences in 86-88 and 89-91 as well...I just dont like to mix series if at all possible.
Can you post information about swappng T2 rotors, ie; matching letters.
You can swap any 13b rotating assy for any other one. We'll assume you're keeping your eccentric shaft, those rarely wear out or tear up unless they saw an oil system failure or were abused. Other than that, the rotating assy consists of both rotors, the front counterweight that goes under the front cover, and the rear which can be a stock manual flywheel with integrated counterweight, an automatic rear counterweight for use with an aftermarket flywheel, or an automatic rear counterweight for use with the auto tranny. The only time you dont have to use all these parts from the same year/rotating assy is if you are having the parts balanced by a pro...in which case they PUT the parts into balance by shaving metal where necessary.
Obviously you would NEVER want to run different rotors...they need to match in compression ratio and weight. Here's the differences back to 84, that's the oldest that I've worked with.
-84-5 GSLSE 13b nonturbo, 9.4:1 CR, 11.5lb each, uses 3mm apex seals and thicker side seals than all 86+
-86-88 FC 13b nonturbo, 9.4:1 CR, 10.5lb each, uses 2mm apex seals and thinner side seals (same for all 86+, 2mm seals and thin sideseals)
-87-88 FC 13B turbo, 8.5:1 CR, 10.5lb each
Note that after 88, the rotors got lighter, but they also got weaker. Detonation can dent in the face of the 89+ rotors, so some prefer the older ones for their strengths.
-89-91 FC 13B nonturbo, 9.7:1 CR, 9.5lb each
-89-91 FC 13B turbo, 9.0:1 CR, 9.5lb each (this is the same as an REW, RE, or 20B motor)
Note that all rotors up to 93 used the same rotorbearings, with a shallow oil passage in the center. The later bearings had a thicker passage to retain a bit more oil, so this should be considered if building a performance engine, you may want to use the later bearings even if the originals were useable.
-93-95 13B-REW, -RE, 20B, 9.0:1 CR, 9.5lb
As far as rotor weightcodes/letters, it's simple. They are lettered A through E, each representing a different weight code. You want to stay within one letter of each other, such as C and D. IF you can get 2 of the same letter, that's the best balance you can obtain without getting a professional to rebalance. It could be said that rotors are balanced from the factory because of this.
For instance, if you were dealing with FD rotors, they're suposed to weigh right at 9.5lb with no bearing. An FD rotor with a weight code A might actually weigh 9.70lb, while a Fd rotor with a weight code E might weigh 9.30lb. Those are not actual numbers, but you get the idea. Mazda knew their manufacturing process wasn't perfect, so rotors had different weights. Their solution was to weigh them and mark them a certain range, so that the engines would be closely balanced to one another, for the best smoothness and power possible from a mass produced engine.
Oh, and if you've ever seen the circles drilled out on the sides of rotors randomly, that's how they balance each tip of the rotor. During their process, one tip may have settled with more material than another, so sometimes they had to drill material out so that one side wasn't heavier/more massive than the others.
The next change for the rotors was for the RX8.
Old Oct 15, 2008 | 08:47 PM
cordius's Avatar
I know the 8's rotors are dipped in titanium, not sure about the 7's. I also know that they are pure titanium rotors that are fantastically light and can take a beating.
Old Oct 15, 2008 | 09:09 PM
OneRotor's Avatar
RAWR
*scratches head* I HIGHLY doubt that they are dipped in Ti, and i don't think ANYONE makes a Ti rotor, as it would have to be machined from a solid block of Ti (do you know any aftermarket company that has the technology and capital to invest into sand casting?), and would be insanely expensive.
Old Oct 16, 2008 | 03:44 PM
cordius's Avatar
It's what I read on RX8club...*Shrug*
Old Oct 16, 2008 | 06:49 PM
Trout2's Avatar
You might be referring to this. FD rotors have a poor casting with inconsistencies in thickness, which can lead to hot spots on the rotor. S4 (87-88 turbo) low compression rotors are used by some building turbo motors due to the stronger casting. The other benefit is the lower compression ratio allows you to run more boost at the sacrifice of low end response. Lighten these rotors and you have a nice setup. This is how Carlos Lopez likes to build his turbo motors.
Jack
jsesq
27
Sep 25, 2015 11:10 AM
yetter227
20
Sep 5, 2015 11:57 PM
VTECthis
Aug 24, 2015 09:01 PM
