whats up with this boost pattern?
Old May 13, 2002 | 02:57 PM
Kahren's Avatar
i am not a girl
car is stock for teh exception of a DP
in 1st i get 11..8..10
in 2nd i get 11..8..10
and 3rd and up i get 11..8..10 up until about 6k rpm
and then 6-8k rpm it falls off from 10 to about 6 or 7 psi depending on weather..
any ideas?
Old May 13, 2002 | 03:10 PM
ejmack1's Avatar
Lawn Ornament
sounds pretty normal to me
Old May 13, 2002 | 03:18 PM
Kahren's Avatar
i am not a girl
i though i was supposed to have all 10 psi all the way up to teh redline...btw i ran a 1/4 of 13.57
Old May 13, 2002 | 03:22 PM
Kahren's Avatar
i am not a girl
i though i was supposed to have all 10 psi all the way up to teh redline...btw i ran a 1/4 of 13.57 with a not so good clutch and pretty dead shocks..
retard slow *** forum posted 2 of these mesagges..
Old May 13, 2002 | 03:29 PM
Mahjik's Avatar
Mr. Links
This is what your boost cycle should look like:
At WOT, 3d gear, everything stock, boost cycle is (rpm's approximate):
rpm ---- psi
3,000 -- 10
4,500 -- 8 (as 2d turbo comes on)
4,500+ 10 (recovers almost immediately)
6,000+ 8 (and holds to redline)
Old May 16, 2002 | 02:46 PM
Kahren's Avatar
i am not a girl
why does it boost lower above 6k? this is normal and supposed to be stock?
Old May 16, 2002 | 02:53 PM
maxpesce's Avatar
Ex fd *****
rpm ---- psi
3,000 -- 10
The Boost should TAPER off from 10>8 after 6k rpm This is because the STOCK setup dosen't flow well enough to maintain 10psi to redline. With a DP and Catback you should be holding 10psi (or better) to redline.
With my setup I get 11-8-11 normally and hold at least 10 to redline when the air temp is below 50 I get 12-10-12
Try doing the Air box Mod to improve flow to the turbos and add a CatBack to reduce ehxaust restriction. should then hold 10+ to redline with no problems.
Old May 16, 2002 | 03:12 PM
vosko's Avatar
Just Call Me Terminator!
cough
13.57 on gtech
cough
Old May 16, 2002 | 03:18 PM
Kahren's Avatar
i am not a girl
hey vosko have u ever used a gtech? and did u use it on a FLAT road and did u calibrate it ? have u done so while at the track? thought so...
Old May 16, 2002 | 05:09 PM
vosko's Avatar
i don't care what gtech says. the track gives timeslips
i have a gtech i don't use it. i would rather goto the track
Bauer778
Nov 4, 2015 04:42 PM
alexdimen
20
Oct 23, 2015 01:50 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
