My new Custom front struts FC
Old Sep 16, 2008 | 10:25 AM
yallgotboost's Avatar
Here are a few pic of my custom Bilstein front struts I built at my shop RTM Performance. Valving was done by my friend Tim Johnsrod of Theory In Practice Engineering (http://www.tipengr.com) car will be road raced NASA Super Unlimited
Old Sep 16, 2008 | 11:36 AM
justint5387's Avatar
CPS Motorsport
How much are they? I want to go a similar route for my FB front strut
Old Sep 16, 2008 | 12:41 PM
Still in R&D stages right now will know more in a few weeks once i get some testing in. The struts are made of Dom tube with a SAE 841 oilite bronze bushing and a wiper seal to keep things clean. Struts can be valve to your cars specs.
Justin5387: I have a set of 1st gen struts im starting to work on now. Ill keep you posted.
Old Sep 16, 2008 | 01:04 PM
CPS Motorsport
Oh cool, Some question I have about them when you are finished. What kind monotube or twin? brand? how high of a spring rate can it handle?
Old Sep 16, 2008 | 01:31 PM
tigermack's Avatar
CPS Motorsport
Awesome... I'd like to see one for the FB, too.
Old Sep 16, 2008 | 02:11 PM
The inserts are Bilstein Mono tube 36mm piston they can be valved for pretty much any spring rate you need.
Old Sep 16, 2008 | 02:33 PM
tigermack's Avatar
CPS Motorsport
Just curious, do you know the price range yet?
Old Sep 16, 2008 | 06:56 PM
YaNi's Avatar
RIP Mark
Looks very nice. Will Ground Control coilover sleeves fit or do you have your own design?
Old Sep 16, 2008 | 08:36 PM
Not really sure on price yet need to add things up. As for coilover sleeves yes GC should fit i used the same sleeve and hat that i had on my stock style struts. I got the parts threw my friends shop A1 Racing.
Old Sep 16, 2008 | 08:53 PM
j200pruf's Avatar
RIP Icemark
So yall this is just the bilstien inserts that work in regualr FC tubes, but you made a custom tube instead?
Old Sep 16, 2008 | 10:17 PM
jgrewe's Avatar
GET OFF MY LAWN
Where they taken apart and revalved? And if so, how did you get the gas back in, I don't see a valve.
I was about to rip apart an insert and see if I couldn't do something in the area around the top stud to install a shrader valve or make a port for an external canister. I was thinking of just replacing the top stud with a bigger one and gun drilling it.
I like the extra wheel clearance you built in with the longer clevic plates.
Old Sep 17, 2008 | 07:15 AM
No these aren't the standard FC insert these are Bilstein's heavy duty 36mm piston inserts. The rear I'm running 2 Bilstein SN series take apart shocks. The original plan was to run a remote reservoir so I could just re-valve them. I have an extra insert all setup with a remote reservoir. Due to time restraints looking to get out with the car in a few weeks I just went with sending the inserts to Bilstein to be re-valved to my specs. Plans are to change over to a remote reservoir over the winter. That's one of the reasons the struts are still in the R&D stages.
Old Sep 17, 2008 | 07:17 AM
struts are for my NASA SU fc running 17 by 11" wheels up front just wanted a little extra space for the springs
Old Sep 18, 2008 | 02:11 AM
j200pruf's Avatar
RIP Icemark
Ah, do those inserts require a custom tube?
So does moving the strut in like that for wheel clearance have any ill effect on the suspension?
Old Sep 18, 2008 | 12:28 PM
Yes they require a custom tube there a lot larger then the FC insert. No ill effects that i could measure. Camber changes at the same rate as factory when the wheel is turned.
Old Sep 18, 2008 | 05:32 PM
thetech's Avatar
****** of disaster
Don't mean to be rude, but isn't this essentially the same setup that AWR has been selling for years? They sell their strut tubes for about $350/pair.
Old Sep 18, 2008 | 06:12 PM
Maybe I've never heard of AWR. I just built these for my car and after some testing if they work good i might sell them. I searched Google and looked at AWR those are just housing you stick a stock insert into. The setup I'm running has a bigger strut and the bushing is built into the housing
Old Sep 19, 2008 | 01:24 PM
thetech's Avatar
****** of disaster
The AWR housings also fit the Koni RACE inserts (including the 8611 double adjustable series) which is what I am running.
Old Sep 19, 2008 | 09:07 PM
Nice How do you like them?
Old Sep 20, 2008 | 11:31 AM
RX-Heven's Avatar
I'll blow it up real good
Nice work
Snoopy FD
Dec 8, 2015 01:45 PM
