DUMB question...Can PVC handle turbo intake temps??
Old May 10, 2002 | 09:21 PM
Bambam7's Avatar
I came, I saw, I boosted.
Can PVC elbows handle the heat of intake air after the turbo? Or what about ABS?
I just can't seem to find silicone ones anywhere.. and I'm sure they are expensive.
I'm sure there are elbows and pipes designed for high heat available through hardware stores, etc....just can't seem to find any.
How hot do those pre-intercooler temps get anyways at 10 PSI?
Thanks...
Old May 10, 2002 | 09:30 PM
Icemark's Avatar
its more the temp of the engine compartment than the intake temps. With any luck the intake temps are lower than the engine compartment temp.
Old May 10, 2002 | 09:41 PM
Bambam7's Avatar
Really??
That's interesting... I would have thought that post-compression temps would be very high! (Like 200 degrees F?)
Well... I suppose I could wrap the tubing with thermotec or something...
Old May 10, 2002 | 09:50 PM
Ridge Tech's Avatar
mines running just fine. I've also added a heat sheild around the air filter sence this picture.
warning 1600x1200 image
http://www.devilmotorsports.com/DSCF0004.JPG
Old May 10, 2002 | 10:46 PM
Bambam7's Avatar
That's radiator hose? Alright.... what about the straight sections? Looks like balck PVC- is it?
Old May 10, 2002 | 11:17 PM
Evil Aviator's Avatar
Rotorhead
Originally posted by Bambam7
Really??
No, you are correct. The under-hood air temp is only about 30 deg F above ambient. I have seen PVC used before, but I don't think it's a good idea. Thermo wrap would just make it fail faster.
Old May 10, 2002 | 11:53 PM
Roy James's Avatar
My cars louder than yours
i have seen a TT 351 in a Thunderbird supercoupe and he seamed to be running just fine. Though im not too sure about the intake temp of the 351TT vs the intake temp of a 13BT, i would say **** it and try it, and monitor it closley. Maybe some of that black piping, damn, whats it called? supposed to not shatter like PVC does or some ****...hhmm... oh yeah, its called ABS. You wont know until you try, hell, i was thinking about trying it until i could get someone to fab me some.
Old May 11, 2002 | 07:52 AM
RETed's Avatar
Performance takes money.
Speed takes money.
How fast you want to go?
Sure, you can get cheap and use PVC and ABS.&nbsp Both will soften and MELT at 200&#176F.&nbsp Outlet temps from the turbo at 10psi will easily get over 150&#176F.
Do you know what "PVC" is?&nbsp PVC stands for poly-vinyl-chloride.&nbsp When PVC melts, it EMITS chlorine gas.&nbsp Chlorine gas is CORROSIVE and eats metal.&nbsp You're softening PVC...making it emits corrosive chlorine gas...which gets sucked into your engine.&nbsp That makes for a very nice picture!
Turbonetics and Baker Precision both sell silicon hose.&nbsp Save your money for it.
http://www.turboneticsinc.com/
http://www.bakerprecision.com/
-Ted
Old May 11, 2002 | 09:56 AM
Aaron Cake's Avatar
Engine, Not Motor
ABS is better at high temps than PVC, but neither is really the best choice. I have lots of experience with using ABS at high temps, and it begins to soften quickly after a few minutes. About 30 seconds later, the pipe fails catastrophically which usually results in a major hole ripping in the pipe...
Bambam, most good exhaust shops will be able to sell you stainless pipe for not too expensive. I picked up a 10 ft length of 403 stainless (2" diameter) for $80.
Old May 11, 2002 | 10:54 AM
Bambam7's Avatar
OK- I can use metal pipe for the straight sections- it was just the elbows I was looking for. I wanted to use pre-made ones. I don't want to be bending and welding pipe sections right now... I'd prefer to be using a modular setup for now, while I am moving everything around.
Basically I had forgotten about using radiator hose for the elbows- I guess I should have payed attention looked under the hood of a TII!!!
Problem solved.
I will definately not use PVC. I know the degredation temp, and I know it's chemical compostion- I just needed to know what temp it was good for.
Thanks
FD7KiD
15
Feb 26, 2021 10:12 PM
sherff
Feb 24, 2019 12:09 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
FD7KiD
Aug 17, 2015 11:50 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
