So what happens is I unscrew these??
Old Sep 14, 2008 | 02:54 PM
Prophet3976's Avatar
Talking So what happens is I unscrew these??
If i undo these will the fan disconnect so i can put on new belts?? Or is there no way to avoid taking off the heat shield??
Sorry for pic quality. It was hard to get my hand in there to take the pic with my phone haha
Old Sep 14, 2008 | 03:04 PM
Turbo II Rotor's Avatar
Who Shot the Sheriff?
Yes, it will disconnect the fan. But you don't have to remove the fan to change belts.
Old Sep 14, 2008 | 03:26 PM
You serious? I can get on the air pump belt and alternator belt without disconnecting the fan??
Old Sep 14, 2008 | 03:29 PM
dot_txt's Avatar
My car hates me
Yes you can. Its hard to describe but if you put the belt between 2 of the blades and turn the fan over you will be able to get the belt on the other side of the fan. < Not the best description ever but hopefully you figure it out.
Old Sep 14, 2008 | 04:07 PM
NJGreenBudd's Avatar
rx-for-my-7
Yeah you just get it over one blade at a time then turn it a bit until it's all the way over.
Old Sep 14, 2008 | 06:28 PM
NJGreen, your 7 is sexy my dude haha
Ok, so I got the Alt belt on, now I'm stuck on the Air Pump Belt. One of the circle tracks it runs on is next to the intake box. Do i remove this one to get the air pump belt on? Ive been trying to undo the 3 screws attached to it but i can get the damn thing to stop rotating completely. Any suggestions?
Does any one have a diagram of how all the belts look when they are done? Just to make sure I have everything in the right track before i start her up :-)
Old Sep 14, 2008 | 06:52 PM
Acesanugal's Avatar
Winter Rotary
It isn't rocket science, hon. The belts will only go on straight one way. You can call it trial and error if you wish, but it's pretty simple to figure out which belts go where just by looking at them and test fitting. If you're really concerned, you could just pay someone else to do it. But seriously...it's cake. There's nothing that needs to be removed in order to get the belts on. It all stays in there.
Old Sep 14, 2008 | 07:16 PM
I'm not about to pay somebody to put in one belt. Forums are to ask questions when you get stuck... I'm stuck, I'm asking questions. Plus i cant find a shop near by that is willing to even touch my car.
Is the Air pump adjustable like the Alt?? Its either that or the dude at the auto shop sold me the wrong belt ( they've sold me the wrong rotors and brakes before too... bastards )
This is the first time I've ever put belts on by myself.
Buuuttt, if you say nothing needs to be removed, i guess i better go put that track back into place and put the screws back in :-). Once i get this belt on I'm finished
Old Sep 14, 2008 | 07:20 PM
clokker's Avatar
Cake or Death?
Yes.
The adjusting bracket is below the pump.
You're going to have to loosen the air pump to make some slack for the belt. There should be an adjuster bracket under the air pump if I recall correctly.
Old Sep 14, 2008 | 08:11 PM
BolognaBlake's Avatar
I just took the fan off.
With a large pair of channel-locks and a 10mm gear wrench, it took maybe a minute.
Old Sep 14, 2008 | 08:16 PM
Ok?
Old Sep 14, 2008 | 10:03 PM
TitaniumTT's Avatar
people still run airpumps?
seriously? Wow. You know the more graceful way would be to brace a screwdriver against two studs to stop it from turning. Seriously? some ******* channell locks?
Old Sep 14, 2008 | 11:31 PM
It wasn't difficult, nor time consuming.
Old Sep 15, 2008 | 12:14 AM
So i slipped the belt over the fan. Walked to Osh 2 damn times for tools....
SHES ALIVE!!!! My baby is once again active :-)
And what do you mean who uses air pumps? I need to pass smog before my ticket is due. How hot am i riding around in a Rx7 with 2005 tags??
Old Sep 15, 2008 | 12:18 AM
MaczPayne's Avatar
Mac Attack
Did you use the channel-locks to hold the water pump pulley still?
That pulley is so weak and flimsy I'm surprised yours still spin true.
Old Sep 15, 2008 | 07:31 AM
clokker's Avatar
Cake or Death?
If they were metric channel locks he's probably fine.
Old Sep 15, 2008 | 09:57 AM
While I am flattered that many of you think I have a metal destroying death grip, I only gripped them just enough to keep the pulley from spinning.
This is a fairly common practice on many other cars, I'm surprised at the response here.
Driv300mph
19
Jul 11, 2003 11:47 PM
airborne
13
May 12, 2003 10:48 AM
vaughnc
Nov 5, 2002 03:38 PM
Bigbird
14
Oct 6, 2002 07:37 PM
sbrx7
Jan 10, 2002 06:47 AM
