fast idle after many mods, help!!!
Old May 10, 2002 | 04:09 PM
puma's Avatar
canadian monster
OK, guys just the did the following mods.
Remove DT actuator and everything related to it.
Remove the AWS.
Remove the Throttle body coolant.
Now my Idle won't go lower than 1000. I have remove the spring on the coolant sensor (fast idle cam) and got the screw all the way down, just like it is explained on rob robinette's site.
What could be my problem, everything was fine before.
thanks a million
puma
Old May 10, 2002 | 04:14 PM
Dr. Strange's Avatar
Stupid question but you did adjust your idle rpm on your management system didnt you? Sounds like you've thinned the mix too much with the mods and need to make the proper fuel adjustments. Or I could be a dumbass.
Old May 10, 2002 | 04:18 PM
puma's Avatar
canadian monster
huh? i don't think those mods need any fuel adjustment...
I still have the stock ECU
im4u's Avatar
just adjust ur damn throttle screw
Old May 10, 2002 | 05:10 PM
puma's Avatar
canadian monster
where is that
Old May 10, 2002 | 05:17 PM
im4u's Avatar
in front of the throttle body its just a screw with like a dish around it
Old May 10, 2002 | 05:33 PM
Uh .....yea I assumed he had already done that. I was also assuming these were not the mods that were causing the problem. i.e. IC,MP,DP,Catback. I guess I shouldn't assume. So anyway the throttle screw is on the front of throttle body as im4u pointed out. The bolt is 8 mm and then a flat head for the screw make sure you dont snap it.I've seen it happen.
Old May 10, 2002 | 06:35 PM
puma's Avatar
canadian monster
ok but does the thing i have remove makes automatically the car idle higher? There must be something wrong with what i did because i had no problem before removing the throttle body coolant, the aws and the DT
puma
Old May 11, 2002 | 01:18 AM
spooledUP7's Avatar
There and back again
Note: you only adjust the throttle adjustment screw after you have adjusted the Air Adjustment Screw (AAS) and were not able to get the desired results. The AAS is located on the throttle body under the elbow, centered. Flat head screw driver is needed.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
ZacMan
Sep 19, 2015 09:20 PM
83revival
Sep 3, 2015 10:42 PM
TwentyDW
Sep 2, 2015 06:42 PM
