Speedometer stopped working
Old May 9, 2002 | 12:02 AM
Rx-7Addict's Avatar
Rotary Powered
The other day my speedometer/odometer stopped working. All other gauges and dummy lights still work..
Anyone know what this could be?
Also, I think it could be related to when i adjusted the TPS. I noticed a wire coming out of the firewall with a rubber surrounding, which was cracked. Since it was cracked, i examened it and pulled it a little. i think this might have messed up the speedo cable
Stupid me..
Is this repairable?
Old May 9, 2002 | 12:11 AM
RX-7 GT's Avatar
HyperREV.com
ya you probably just pulled it out of the back of the cluster ....and believe me its really really fun stickin your hands or fingers i should say back there to plug it back in
Old May 9, 2002 | 12:17 AM
RX-7 GT's Avatar
HyperREV.com
oh ya....well the rubber hose around the actual speedo cable is just a shield, if the cable itself is bent or twisted it wont give readings.
as long as the actually speedo cable is not cracked or bent it should be fine till you can get a new one.
Old May 9, 2002 | 07:23 AM
KNONFS's Avatar
B O R I C U A
Or it broke (the cable), It happen to me! Ohh, have fun pluging it!
Old May 9, 2002 | 07:47 AM
tesla042's Avatar
It's odd that BOTH the speedo and tach went out... I'm pretty sure that mechanical cable is JUST for the speedo.... I drove around for a few days with it out as I was trying new cluster overlays, and I remember having to judge my speed based on tach...
-Tesla
Old May 9, 2002 | 07:48 AM
tesla042's Avatar
Hey, i'm an idiot...you said speedo/ODO, not speedo/tach... nevermind!
Yeah, it's prolly the cable... the other end goes to the tranny--it could be loose there too.. easier to check that than the cluster (BIG PITA).
-Tesla
Old May 9, 2002 | 10:56 AM
blu_gxl's Avatar
deffinately the speedo cable. it's a matched set and i recomend getting the part at the dealer of mazdatrix if they sell it and try not to mess up the connecting ends because you will need to reuse it with the factory unit. it's realy not that hard to install 1st time took me 1 hr to get it all in and back together 2nd time took me 45 min third time 20 min it wasn't pretty but i'm damn fast about it now!
james
streetlegal?
Mar 17, 2022 02:46 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
andyvideopro
Aug 20, 2015 10:55 AM
smikels
Aug 18, 2015 01:26 PM
