do your vents always blow air?
Old May 8, 2002 | 12:49 PM
BigRed's Avatar
I've had my new (2nd) FD for about 2 weeks now, and I've noticed that my vents always blow a small ammount of air all the time. Is this normal? I've gone from a '94 Touring to a '93 R1 and I never noticed this on my last car.
Also my airbox on my last car was busted and I 've never before heard the wooshing sound that I get when I accelerate. It's relatively loud. I'm assuming it's the airbox, I've never noticed it in my friend's FDs, but I just might have not been paying attention. I had a 4 hour each way drive this weekend, so I got to listen to my car alot
Just want to make sure everything is fine.
Thanks.
Bigred
Old May 8, 2002 | 12:50 PM
alwan16's Avatar
mine sometimes blow air even after i've turned the things to off. weird. i think it is some kind of electrical gremlin.
Old May 8, 2002 | 12:51 PM
Lost Time's Avatar
Chimera Driver
If the a/c button is not pushed in (lit up) you will always get a little air when the car is moving. With the switch in, you should get nothing.
Old May 8, 2002 | 12:53 PM
SaltyDog12's Avatar
yeah, if you hit the recirulate button. it will close of the outside air
Old May 8, 2002 | 12:54 PM
BigRed's Avatar
I'll check the A/C thing out. if that's the case I won't worry about it (not that I really did anyway).
Thanks for the quick response.
Old May 8, 2002 | 01:59 PM
nocab72's Avatar
03 Cobra Killer
ya, what Lost_Time said. Also as far as your intake whoooshing sound, mine is quite loud on my 94 touring with Apexi Intake. Never heard it before with the stock airbox, but it is loud now under 1/3 - 2/3 throttle.
K
Old May 8, 2002 | 02:06 PM
alwan16's Avatar
what if my car is not moving?
Old May 8, 2002 | 02:18 PM
Lost Time's Avatar
Chimera Driver
If the car isn't moving you shouldn't have any airflow. Maybe a trickle, unless you're facing a 60mph headwind.
Old May 8, 2002 | 02:27 PM
martini's Avatar
hit the recirculate button like salty dog said.
Old May 8, 2002 | 03:03 PM
twinturborx7pete's Avatar
Juris Doctor
All it is the cowl is open to outside air so air just flows through the cowl into the vents, you hit the recirc button and it closes the cowl up then you won't get any air in the cabin... thats why its called a VENT.
24seven_dada
20
Nov 10, 2018 12:03 PM
yetter227
20
Sep 5, 2015 11:57 PM
