J-Spec ECUs
Old May 8, 2002 | 02:28 AM
InfiniFC's Avatar
Question J-Spec ECUs
Anyone know if the J-Spec FC ECU's are compatible with the ones here?
Thanks!
Old May 8, 2002 | 04:58 PM
vaughnc's Avatar
knowledge junkie
No. Octane & sensor differences.
Old May 9, 2002 | 12:53 PM
RETed's Avatar
If you need a Zenki turbo US-spec ECU, I've still got two available.&nbsp These are 1987 Turbo II US-spec ECU's N332 part number.&nbsp $75 shipped anywhere in the U.S.
-Ted
Old May 9, 2002 | 01:17 PM
InfiniFC's Avatar
-Ted
Aww shucks... I'd like to get one, but I'd need one for an 89-91 ECU. Sold the 87 already. I saw this kit at THEPARTSTRADER.COM, and was contemplating on getting it.
http://www.thepartstrader.com/Single...=101&C2ID=1004
JUN tuned ECU, but J-spec.
Old May 9, 2002 | 02:15 PM
darkwaveboi's Avatar
Need donor car in Fairfax
so a jspec ECU wont work w/ our engines, but our ECU's will work w/ a Jspec engine?
Old May 10, 2002 | 04:35 PM
InfiniFC's Avatar
Question
Good question. Anyone know what the ECU designations are for J-Spec FCs? Or the 89-91 ECUs for that matter? I just know the 87-88 ones are N332.
Old May 10, 2002 | 04:39 PM
Ryde _Or_Die's Avatar
Ok, wut if you put in a jspec engine? Then you need a jspec ecu correct? Oh and with the jspec engine, the A/C and everything works right? Thanks.
RETed's Avatar
1989-1991 Turbo II U.S.-spec - one of them is an N370
-Ted
Old May 10, 2002 | 05:06 PM
Piranha's Avatar
what 7
With the help of the knowledgeable people here, I've discovered I have my old ECU, for an '88 TII, running my 89+ Jspec engine. So it works. And those Rustangs know it!
Old May 10, 2002 | 05:58 PM
vosko's Avatar
Just Call Me Terminator!
i'm running the panspeed jspec on my 89 TII works perfect
Old May 10, 2002 | 10:03 PM
doh
Old May 13, 2002 | 04:08 PM
InfiniFC's Avatar
Question
So, it plugs up with no probs? Technically hooking up a AFC or ACV-R should work too then right?
Old May 13, 2002 | 06:35 PM
vosko's Avatar
yeah it plugs right in. why wouldn't an afc or avcr work. if you go that route you need a FCD also
Old May 13, 2002 | 08:26 PM
InfiniFC's Avatar
OIC, just curious... I'm about to buy a JUN Tuned ECU along with some other goodies. I just don't want to mess up the car, or the wire harness with a non compatable ECU.
Got an FCD, FD Fuel Pump, and 720cc injectors in the secondaries coupled though an Super AFC. I'll probably swap out the 720ccs for stock injectors, and use the 720ccs as 2 additional injectors.
Thanks for the info everyone...
Old May 13, 2002 | 08:27 PM
vosko's Avatar
you don't need FCD with a tuned ecu they get rid of the fuel cut with the programming
FC_DREAMS
20
Sep 22, 2015 09:43 PM
FC_DREAMS
Sep 9, 2015 06:24 PM
NOTA V6
Dec 3, 2001 02:44 PM
Rotarybuddy
13
Nov 19, 2001 09:29 PM
rotarymaz
Nov 6, 2001 11:06 PM
