Just replaced Oil Pedestal O-Rings! Props to...
Old May 7, 2002 | 03:28 PM
RarestRX's Avatar
NA Powah, Every Hour!
Yo,
Props to Tesla042 for this procedure:
http://haxx0r.net/car/rx7/oil_ring/
I replaced the o-rings, they were more like gaskets when I pulled them out: squashed flat.
The procedure was easy enough, just have a small 10mm open ended wrench, it's a tight fit in those quarters. I took longer so I could clean off all the caked oil all over everything.
I took it around the block, no leaks!
Thanks again Tesla!
KS
1989 GTUs "No more Exxon Valdez on the garage floor..."
Old May 7, 2002 | 03:38 PM
Samps's Avatar
You waited this long to do that? Shame on you! I did it the second I saw the how-to procedure. It's a good time to remove your oil pressure sending unit for a good cleaning also. This is one of those things to do when everything is running right and you are just looking for a reason to start wrenching.
FD7KiD
15
Feb 26, 2021 10:12 PM
alphawolff
Nov 17, 2015 05:57 PM
sYnth.
Aug 19, 2015 06:27 PM
FD7KiD
Aug 17, 2015 11:50 PM
