My power steering removal pics
Old May 7, 2002 | 02:19 PM
BoostedRotors's Avatar
I HATE sleepy eyes
So no one ever had pics of this...so this is what I did:
first I cut these lines:
then I simply looped the two together and then plugged the other holes (there were 5 of them):
Thats it...anyone know if this is gonna work? I dont see why it shouldn't...but this is my first time doing this. any feedback?
---Nick
Old May 7, 2002 | 10:24 PM
vaughnc's Avatar
knowledge junkie
bumpity bump
Old May 7, 2002 | 10:34 PM
prmazdarx7's Avatar
not that i am a pro and i am not but here is my take on this i have not done any of this but if i was going to do what you did i would go buy some sort of fitting so that you can bleed it every now and then kind of like the ones for bleeding the brake system
what does everyone think of my idea??
Old May 7, 2002 | 10:46 PM
prmazdarx7's Avatar
woops double post sorry
Old May 7, 2002 | 10:53 PM
Xentrix's Avatar
Kill Bear
Cool pics, but isn't that more of a modify your PS to Manual instead of the full swap. I did the full swap in January, now that is a total bitch to do especially if the engine is still in.
Old May 7, 2002 | 11:09 PM
rico05's Avatar
WTB S5 N/A FC
Keep us posted on how it works for you!! I might do this when I get my TII...
Old May 7, 2002 | 11:10 PM
SonicRaT's Avatar
Super Raterhater
I did something similar, except I left those lines alone, and I plugged up the 3 that go to the cooler & the pump.
Old May 8, 2002 | 02:43 AM
I HATE sleepy eyes
Sonic, did that work for you? that would have been a shitload easier....where did you find the bolts to plug with?
Old May 8, 2002 | 02:54 AM
SonicRaT's Avatar
Super Raterhater
I had some bolts lieing around and I used some rather large washers with gaskets, it's working so far but, then again I haven't had the car on the road to give it a real test. I'll let you know whenever my car gets running!
Old May 8, 2002 | 08:42 AM
tmak26b's Avatar
I dont know how the steering react with the lines plug in like that vs taking out the steering belt. But in my opinion, when I drove around without the power steering wheel. It had to be the worst feeling, the steering is slow and heavy, cant turn for crap
Old May 8, 2002 | 09:37 AM
tesla042's Avatar
Huh.. I *LOVE* the feeling of my p/s with the belt off.. With it on, it feels too much like a toy... I can turn it with my pinky..
Now, sure, it's a little tricky to parallel park, but you just gotta work those muscles.. Above ~2 or 3 mph, it's no problem at all to turn. On 225 tires, even..
I'd never go back.
-Tesla
Old May 8, 2002 | 10:06 AM
ponykiller's Avatar
If you do that, you should completely drain all the fluid out of the rack. If you do not, then every time you turn, you must move all that fluid around and overcome friction witht the road. Needless to say, it would be much easier without the fluid. Note: There is no reason to still have the fluid in there.
Kris
Old May 8, 2002 | 10:07 AM
tmak26b's Avatar
My car has the RPM sensitive p/s, it is a little stiffer
Old May 8, 2002 | 10:35 AM
phinsn98's Avatar
Kris
I'm sorry but your wrong...you have to keep the fluid in the rack to lube the seals. I have done this but looped the lines that go to power steering pump instead of the lines on the rack. I then plugged the line to the oil cooler. It works fine, gives much better feel for the road. I have heard the the TII is supposed to have speed sensitive steering, but my car always seemed to feel like a Cadi when driving down the freeway. Now it feels like a sports car.
Later
Old May 8, 2002 | 01:32 PM
RexRyder's Avatar
i just removed the belt
Old May 8, 2002 | 01:59 PM
SureShot's Avatar
Seduced by the DARK SIDE
My S5 RPM sense PS pump will probably come off soon. The change in feel in parking lot/autocross turns is a PITA.
Th0m4s
Feb 26, 2019 02:04 AM
ItsJBohmzB
171
Apr 24, 2017 01:11 PM
LunchboxCritter
15
Jan 3, 2016 04:11 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
