ECU compatablility question
Old Jul 15, 2008 | 10:57 PM
Burnin_streets's Avatar
87 NA build in progress
Will the ECU from an 86 GXL work for a 88 vert?
Old Jul 16, 2008 | 10:11 AM
HAILERS's Avatar
HAILERS
A N326 or N327 will work peachy keen fine all day long.
Old Jul 16, 2008 | 10:44 AM
Hailers, you're the man!
Old Jul 16, 2008 | 10:54 AM
Icemark's Avatar
No, the vert uses a N338 not a N326 or N327.
If the first three digits match (N32) or (N33) you can use any other ECU that uses that same 3 first digits.
So a N332 or N333 or N338 could be used interchanged,
On a car using a N327, a N326 could be used, but not a N333.
The 3rd digit refers to the engine harness series used in the car.
Old Jul 16, 2008 | 11:03 AM
so no :'(
Old Jul 16, 2008 | 11:55 AM
HAILERS's Avatar
HAILERS
Got me. I look in the FSM Control Unit page and don't see different values for a convertible vs a stock manual car, much less a different value for the pressure sensor output. But the convertible uses a turbo pressure sensor (Control Unit page makes no mention of that).
I'm probably wrong. Ain't no Mazda tech.
Then again, I'm using the online manuals that all seem to say 86-88 FSM. There's no strictly 88 FSM, and that could be MY problem. I'll never know since there's no strictly 88 FSM online.
Old Jul 16, 2008 | 12:21 PM
Its cool, thanks for trying tho and I'm always stoked when you help out with a problem. I'm just sad they won't swap.
Old Jul 16, 2008 | 01:00 PM
HAILERS's Avatar
HAILERS
Well, I see where I'm thinking wrong. The two different ECU may see the same signals but what the individual ECU does with that signal is another thing.
Jpg out of the free online parts fische attached of the right conv number.
By the way, what number is on YOUR ECU???? Getting rid of it? Wanna sell ...cheap?
Skeese
65
Mar 28, 2017 03:30 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
