Engine reassembly 12a ????????
Old May 5, 2002 | 04:16 PM
Quote from Haynes manual "Mesh the internal gear & stationary gear so that the rotor is in the same location as when disassembled. The rotor is easiest to install with one apex pointed towards the top of the engine & the other two symemetrically on either side"...... OK my problem I forgot to check & take note where my rotor was, DUH Any help thanks
Old May 5, 2002 | 04:28 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Dont matter, it will only go together one way...
Just make sure the Front rotor stays in the front and the rear stays in the rear ...
Old May 5, 2002 | 11:07 PM
Yea it only goes together one way!. I just built mine and runs good, will be better after I figure out this fuel problem!.
Old May 6, 2002 | 04:23 AM
Project84's Avatar
Open up! Search Warrant!
Just make sure there aren't any spare parts when your done
Old May 6, 2002 | 05:01 AM
riffraff's Avatar
smog nazi destroyer
blah.. no reason to be afraid of spare parts.. just think of them as extras.
Old May 6, 2002 | 09:33 AM
MIKE-P-28's Avatar
When you buy a fukll rebuild gasket kit from mazda there are a few o rings left over... I still to this day have some, and I looked and looked and never seen where they went...
When putting the motor back together: When your do the rear rotor, its easy. When you go to do the front one, you have to put the inter. housing on and to do that you have to pull up on the e shaft. Its a real bitch to keep the apex corners from flinging out you have to be super careful you dont loose a apex corner and not know it. Heres my advice on that, get some super glue, lay the apex's on the workbench, super glue the corners to the apex seal so they cant move easy. Put it together still being careful. Got that advice from Mazdatrix. He said that the super glue would get burnt off and the apex would be back to normal Good luck
Old May 6, 2002 | 05:50 PM
Thanks Mike. I'll do that, I almost lost one when i tried removing the shaft. I'll be putting it all back together tomorrow, I have finnished cleaning & painting & street porting it, will be interested in the difference, although apart from the major oil leak, the inside of the engine was fairly clean & in good condition.
The1Sun
Mar 18, 2018 11:08 PM
rx7brandon
Aug 16, 2015 10:55 AM
Marty RE
Aug 13, 2015 11:19 AM
