1000 HP+ 13B Turbo's...
Old Jul 9, 2008 | 06:04 AM
pmr eng's Avatar
It's seems there are quite a few 13B's stepping up (colon, pica, Nayeli and Rafaelito) with huge mph and unimaginable times especially those in puerto rico, just wondering what combinations are they running and port configuration?
What are the advantages of running Semi-PP over PP turbo or vise versa?
As well, billet cranks, are they essential for sustaining big hp or just sustaining high rpm?
Would appreciate your inputs
Thanks!
Old Jul 9, 2008 | 07:38 AM
felix_is_alive's Avatar
i think there is a thread on here somewhere , that goes into this ,
i think there is even a vid of a 13b being dyno`d at 1000hp+
Not shure , but i think i read that before
do a search for 1000hp 2 rotor , you should find this , it is pretty old though
Old Jul 9, 2008 | 11:59 AM
ultimatejay's Avatar
Pretty easy- most are using Semi pports, tons of fuel and boost and a good tune and internals/seals. There's only so much you can do to a rotary to make power. It's keeping it all together and making it last that's the trick.
Old Jul 12, 2008 | 01:38 PM
neit_jnf's Avatar
gaby skern's 6.97s engine is using:
10,500 rpm redline
Extreme Rotaries center bearing billet eccentric shaft and engine balance
Extreme Rotaries stud kit
'88 8.5:1 rotors
3mm one-pc NRS ceramic apex seals
'94 Semi PP rotor housings by Gaby Skern, engine built in PR by him
Mike Turbo custom 88mm turbo with 5" down pipe
40psi controlled by Turbo Smart eboost-2
Gaby Skern custom turbo mani and billet aluminum intake mani built by Limon Machine Shop
Accufab 80mm throttle
Rons Fuel mechanical fuel fump (methanol)
3 Wilson Manifold fuel rails with a total of 12 1600cc injectors
'89 Cosmo ignition system with 2 MSD DIS-4 and 4 MSD Blaster DIS coils
Microtech LT12S X6 tuned by Gaby Skern
Old Jul 13, 2008 | 02:33 PM
10,500 rpm redline
'88 8.5:1 rotors
Like I said above- lost of fuel and boost! Nothing rocket science there, just takes money and a little know how.
Old Jul 17, 2008 | 07:43 PM
ronbros3's Avatar
billet center bearing cranks are essential, picture in your mind a rotating Eshaft bending under hi torque load, what happens to the rotors when they touch the side plates, and the Apexs wont follow the rotor housings, its a mess trying to get into trouble, it takes torque to make 1000hp at only 10,000rpm. these guys have been thinking for a long time, and probably got a pile of blown engines as high as a two story building. Thx Ron
Old Jul 20, 2008 | 05:22 AM
Jaime Enriquez's Avatar
OLDROTA
The "Adriana is Back" Starlet last dyno was in the 900's at the wheels....that's over 1000 at the fly.......that seems to be the "reliable" numbers on 13B's....incredible though!
http://dragsterspr.com/Sequence%2001dyno%20trs.wmv
Old Jul 26, 2008 | 01:29 AM
Glassman's Avatar
Thanks, I'm glad to see someone get it right
Old Jul 26, 2008 | 01:59 AM
OLDROTA
Anyone know what wastegate he's running?
Old Aug 1, 2008 | 06:42 AM
zack4173's Avatar
10,500 rpm redline
'88 8.5:1 rotors
holly crap 12 1600cc injectors thats just hard for me to even imagine that kind of fuel.
ncds_fc
Aug 15, 2015 10:06 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
