Haltech haltech boost controller
Old Jul 5, 2008 | 05:50 PM
myersprostatus's Avatar
torretos stunt double
Hey everybody, quick question.
i just bought the haltech boost controller along with a haltech e8/air temp sens/bar sensor. i have everything hooked up except the boost controller because i dont know where the two brown wires coming out of go too. what do i splice them too?
could you guys help me out asap cause i want to get it running today, it would make my day .
thanks
mitch
the boost controler model is the haltech boost controller/ boost solenoid
Old Jul 5, 2008 | 06:04 PM
C. Ludwig's Avatar
www.lms-efi.com
The wires are not polarity sensitive. So one side goes to switched 12V+ the other to the PWM output you are using for boost control from the Haltech. Doesn't matter which one goes where. Your dealer should provide this information.
Old Jul 5, 2008 | 06:09 PM
alright, thanks
what about the wastegate? doesnt thew stock wastegate only have one port?
i only see one
Old Jul 5, 2008 | 06:27 PM
sorry im such a n00b when it come to techies.
im just a kid, where exactly is the PWM? the instructions included are pretty bad and frustrating...
im kinda lost.
Old Jul 5, 2008 | 06:39 PM
the two wires the come off the boost controller solenoid do the hook up to pins D(grey wire) AIR and pin E(blck wire) ground of the auxillary connector?
the instructions are pretty bad and this will really help me out guys. the haltech is a haltech e8 BTW.
thanks
-mitch
Old Jul 5, 2008 | 08:48 PM
88rxn/a's Avatar
tom port.. AKA streetport
HALTECH manual should have a wiring diagram in the back.
Old Jul 6, 2008 | 12:40 PM
the wiring diagram is shat.
it doesnt show any PWM in it.. so i have no idea where to hook the two solenoid wires up to.
please someone help me.. or ill have to spend a shitload of money to get my car towed somewhere.
Old Jul 6, 2008 | 02:00 PM
13B-RX3's Avatar
7s before paint!!!
Hook the PWM output #1 V/W (assuming it's not already being used) to one of the wires to the boost control solinoid. Hook the other wire from the solinoid to a 12V switch ignition source.
http://www.haltech.com/downloads/E8%...0Connector.pdf
No offense, but if you cant figure how to wire it there is not a chance in hell you are going to be able to configure it and tune it. It's not just a matter of hooking it up and telling it how much boost you want to run, there is much more to getting it to work properly.
For the record, Haltech's wiring diagrams are very good IMO. Or at least better than what i work with every day.
Good luck to you and when you start to configure it search this section. There is some great info in here if you are willing to search.
Old Jul 6, 2008 | 08:45 PM
im getting it tuned at a shop
Old Jul 8, 2008 | 12:32 PM
wow thats a nice wiring diagram i didnt recieve anything like that in my haltech package
Old Jul 8, 2008 | 01:02 PM
true the wiring diagram is pretty simple, that is if your starting wiring from scratch, but im using the stock wiring with the plug and play e8. If anyone has done this before could you throw me a hand?
Old Jul 8, 2008 | 02:22 PM
C. Ludwig's Avatar
www.lms-efi.com
You have a PM. Easy S5 install tips for others...
The body of the controller is stamped with the 1, 2, 3 number for the ports. When you wire it up the polarity of the wires doesn't matter. One side will go to switched 12V+ and the other will go to the output from the ECU. The easiest way to install it is in place of the stock duty control valve which is located in the rats nest. It is fed by blue/white and black/white wires. Simply cut the stock connector off and wire in the boost control solenoid to those two wires. You can extend the wires and/or add a connector to make installation easier. The reason you use that connector is because the patch loom is already wired to that connector through the stock harness for PWM #3. In the setup software you will then program PWM #3 for closed loop boost control and set it up according to the instructions in the install manual.
MoTeC
Sep 10, 2015 07:58 PM
