Need some help (oil filler neck nipples)
Old May 19, 2008 | 11:50 PM
recardo's Avatar
fd
i need help figuring out what is this hard pipe connected too & oil filler neck. my car recently started leaking fuel so i replaced fpd, fuel lines, and had the injectors cleaned and balance, i testing for leaks by turning on the fp there is this hissing sound coming from the fuel rails is that normal?
Attached Thumbnails Need some help (oil filler neck nipples)-.line..jpg   Need some help (oil filler neck nipples)-.oil-filler..jpg
Old May 20, 2008 | 12:00 AM
ThoRx7's Avatar
well i'll supply you with the diagram and you do the thinking.. well, just follow the diagram..
Old May 20, 2008 | 09:20 AM
Mahjik's Avatar
Mr. Links
The hard pipe connects the the vertical nipple on the oil filler neck. The horizontal nipple on the oil filler neck connects to the UIM and has a valve in the line.
Old May 20, 2008 | 10:30 AM
IRPerformance's Avatar
Sponsor
Run a hose from the hard line that runs across the engine block to the bottom nipple. The top nipple gets a hose to the upper intake manifold with a pcv valve inline.
Old May 20, 2008 | 11:43 AM
recardo's Avatar
fd
thanks, i thought so but i wasn't too sure. and about that hissing sound coming from the rails is that normal?
Old May 20, 2008 | 12:13 PM
Mahjik's Avatar
Mr. Links
When you run the fuel pressure test, you will hear a hissing from the fuel pressurizing the lines. If you expose the rails like this when testing:
https://www.rx7club.com/showpost.php...&postcount=255
You'll be sure to notice anything leaking.
13
Jan 9, 2018 11:19 AM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
