Sponsored by: CARiD
turbo question
Old May 4, 2008 | 03:59 PM
RuffNReady's Avatar
turbo question
plz don't bask me for asking but can a stock non turbo 13b hold up to a small turbo setup if so how many psi can it handle? thanks for any info
Old May 4, 2008 | 07:05 PM
Sideo's Avatar
from what i understand, i havnt looked into fc's since i bought my fd, there arent any aftermarket kits available. and to do it you need to remove the 5th and 6th port actuators to fit the turbo. im sure if you do manage to turbo it you will need some kind of fuel managment and bigger injectors.
Old May 5, 2008 | 02:20 AM
initial D is REAL!'s Avatar
its been done a few times. They have a few threads on NA engines turboed
Old May 5, 2008 | 08:07 PM
RuffNReady's Avatar
yeah i have a stock vw passat 1.8 turbo sittin around and i thought it might be nice to give my SE some extra power.....i would probably build most of the kit myself anyway but what kind of fuel management would you recommend?
Old May 6, 2008 | 02:29 AM
Mazdaracer4fun's Avatar
you will need to rebuild and definitely port both intake and exhaust ports to help get the boost and and out as fast as possible... but overall its cheaper, easier,and more reliable to just buy a turbo II or RE OR REW
Old May 6, 2008 | 07:24 AM
OTT's Avatar
OTT
Representin since '86
If you are serious about doing it the easiest route would be to buy a stock t2 turbo and mani, some kind of carb set up, and get a carb hat built. After that its just exhaust, IC and piping, fuel system i.e. turn your delivery line into your return line and run a bigger delivery line, fuel pump, jetting for the carb, then plumb the oil and coolent lines for the turbo. I wouldn't run more than 5-6 psi and to do this you'll need to port the wastegate or get a different actuator. I'm sure you could run this set up for a while with no problem.
You should also have some mechanical back-round or else your just going to be in over your head.
-Steve
Old May 7, 2008 | 12:50 PM
paros's Avatar
Good luck!
Old May 7, 2008 | 02:55 PM
20Bforme's Avatar
three spinning triangles
Originally Posted by paros
Good luck!
thats what i say... most 6port turbo engines dont last very long
Old May 7, 2008 | 05:10 PM
RuffNReady's Avatar
so pretty much it would be way easier to just save my money and do a t2 swap or some other swap (like a 2jz or rb26)
Old May 8, 2008 | 05:36 AM
20Bforme's Avatar
lol 2jz or rb26... youll be saving your money for a lonnnnnnnnnng time if your gonna go that route...
a t2 swap of the same series would be the recommended way to go...
Old May 8, 2008 | 07:57 PM
RuffNReady's Avatar
well if i decide to go this route it isn't like i'm planing on doing it in a month or 2 if the feedback from you guys is that one of those motors would be in my best interest i would plan the cost carefully and obtain a rough draft of how long it will take to accumulate this amount of money.....how much one these swaps normally cost?
Old May 8, 2008 | 09:03 PM
therotorrooter's Avatar
I'm doing a TII swap in my '88 vert I found an entire 87 TII car for $2000 shipped to my door. I'll have about $2000 to $2500 in additional upgrades, racing beat exhaust, upgraded turbo/fuel system, fmic, and engine mgmt system. I probably could have bought a car cheaper, but hey, I'm having some fun with it and I'll know 100% whats been done to it. Have fun and good luck!!
Old May 8, 2008 | 09:23 PM
calicrewchief's Avatar
RotorHead
http://www.aaroncake.net/RX-7/myrx-7info.htm
I always refer anyone requesting info about boostin an N/A to Aaron Cake. He seems to be the guru when it comes to it. Very knowlegable so look him up.
Old May 8, 2008 | 10:36 PM
RuffNReady's Avatar
thank you very much for the link it was very informing even tho the pics were a little hard to follow...that may be a profect to look foward to in the future but not right now thanks again
hotshot2014
Jul 18, 2017 02:30 PM
smikels
Rtek Forum
May 12, 2016 12:34 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
