Slight smell of gas on dipstick.
Old Apr 23, 2008 | 04:55 PM
88RXVERT's Avatar
Checked the oil...and a very slight smell of gas from the oil on the dipstick... Normal? Should I be worried?
Old Apr 23, 2008 | 05:02 PM
88RXVERT's Avatar
Let me guess..its gonna blow?
Old Apr 23, 2008 | 05:23 PM
93rx74lyfe's Avatar
Ronald..
do you pre mix?
Old Apr 23, 2008 | 05:39 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
it's probably just been flooded before and hasnt had the oil changed yet. more info needed for more accurate diagnosis
Old Apr 23, 2008 | 05:46 PM
Go48's Avatar
You will always have a little fuel in the oil, particularly with a rotary engine, so don't fret. If you are really worried about it, send a sample to Blackstone Labs for analysis next time you change oil to see if it is within the normal range. Only then will you know for sure if it is a problem.
Old Apr 23, 2008 | 06:05 PM
88RXVERT's Avatar
No premix
Ok, I feel better as the smell was very vague.
Off to get it changed.
Thanks!
Old Apr 23, 2008 | 07:20 PM
ericgrau's Avatar
Clean.
Most people with fuel dilution issues get a strong smell of gas. If it's that vague it probably isn't anything. If you do have fuel dilution, you need to change your oil more often to keep the oil from thinning out too much.
Old Apr 23, 2008 | 07:22 PM
88RXVERT's Avatar
Maybe I should use a 20/50w oil?
Old Apr 23, 2008 | 07:39 PM
ericgrau's Avatar
Clean.
Well if it's that vague I wouldn't worry. I guess 20w50 would help thicken it in theory, and it'd slow the fuel/oil leak. But if you really have a problem I'd still change the oil more often even w/ 20w50. And you shouldn't ever use 20w50 if the weather's ever way below freezing (too thick&gooey). I dunno, I'd give it time and see if it's even something to worry about. Plus I hear people with bad fuel dilution tend to get more and more "oil" as fuel overfills the sump.
FC_DREAMS
20
Sep 22, 2015 09:43 PM
Steelwheelz
Sep 15, 2015 03:22 PM
Monsterbox
Sep 11, 2015 03:29 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
