oil injectors??
Old Apr 22, 2008 | 10:19 PM
ducerx7's Avatar
oil injectors??
can i remove the oil injectors from the engine and manifold i have read of people removing them,but nobody ever says what will happen if i do
can anyone here tell me what will happen will it run fine or blow ???
Old Apr 22, 2008 | 11:05 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Well...if you remove the injectors and oil pump without adding premix to your gas tank, then yes, you will destroy your engine.
Old Apr 22, 2008 | 11:11 PM
Destruction will be iminent without pre-mix if you remove the injectors... You should block them off as well... don't think it would work right it they were left open.
Ramses666
Old Apr 22, 2008 | 11:32 PM
fastrotaries's Avatar
W. TX chirpin Monkey
what year? Why removing them?
Old Apr 23, 2008 | 01:09 AM
Yes... why remove? What r U thinkin?
Ramses666
Old Apr 23, 2008 | 01:32 AM
mazda_wes's Avatar
404** File not Found
it is actually good for you to pull and block the OMP in that you will be able to more safely run a heavy synthetic oil in your engine to get some longevity out of it. the problem is that the engine becomes more high maintenance. you would need to add a mixture to the fuel so that the engine still gets the oil that it needs for the apex seals. you will also need to make sure this mixture is accurate or...zoom zoom boom. i would only do this on either a sunday driver or on a car that i was absolutely sure that no one else was going to attempt to fuel up. personally, i won't do it. that is my opinion though.
Old Apr 23, 2008 | 09:29 AM
Aaron Cake's Avatar
Engine, Not Motor
You can run synthetic with the metering oil system just fine.
Mazda's original recommendation not to do it was based on 20+ year old formulations.
As others have said, if you remove the metering oil system you must then run premix so the rotor seals and housings stay lubricated.
Old Apr 23, 2008 | 10:20 PM
ducerx7's Avatar
i was making a after market manifold out of my stock one and was just wondering if removing them help or not
Old Apr 24, 2008 | 05:28 AM
Banzai-Racing's Avatar
Rotary Specialists
Yes, and we have kits now with properly sized metric thread port plugs for installation in the housings where the oil injectors are.
https://www.rx7club.com/showthread.p...00#post8109900
FD7KiD
15
Feb 26, 2021 10:12 PM
sYnth.
Aug 19, 2015 06:27 PM
FD7KiD
Aug 17, 2015 11:50 PM
