spark when spin CAS by hand but not when cranking WTF?
Old Apr 21, 2008 | 04:40 AM
13BSA22C's Avatar
OK,
Long story short, I get spark with CAS out of engine turning by hand but none when actually trying to start it. I get no errors, orange light flashes on MT.
Old Apr 21, 2008 | 05:27 AM
pistones's Avatar
did you just install microtech? check the ground for the shielding on the CAS. also are you using new plugs? are you getting spark at the plugs with CAS in the engine while holding the spark plug wire near the plugs?
Old Apr 21, 2008 | 06:47 AM
13BSA22C's Avatar
nothing has changed. Was working before, not now
Old Apr 21, 2008 | 07:21 AM
Stanello's Avatar
backslash beanbagrace
Connect to the Microtech with a laptop and check if the ECU is seeing RPM while cranking, should be 250RPM or so.
Old Apr 21, 2008 | 08:05 AM
13BSA22C's Avatar
MTX8
NEWGENRX7
Jun 26, 2019 12:20 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
ZacMan
Sep 19, 2015 09:20 PM
Monsterbox
Sep 11, 2015 03:29 PM
Enzo1944
Sep 6, 2015 08:57 AM
