Sponsored by: CARiD
jdm s5 turbo 2 not starting?!!! PLEASE HELP!
Old Apr 18, 2008 | 10:14 PM
Mazdaracer4fun's Avatar
OH jdm s5 turbo 2 not starting?!!! PLEASE HELP!
ok so i have an 88 gxl that i gutted and replaced ALL the wiring with s5 wiring and then dropped in a JDM S5 Turbo2 engine , i havent checked compression yet but i do here the typical whoosh ,,, whoosh ,,, whooosh sounds when i crank it ,
if someone could call me i can explain it soooo much better or pm me your number and i will call you !
THanks alot!
Will H.
216-702-3973
Old Apr 19, 2008 | 09:05 AM
bump still needing some help here!
Old Apr 19, 2008 | 01:26 PM
RW-7's Avatar
Moderating the Trochoid
Are you running the S5 Metering Oil Pump? Check it and everything that goes to it very carefully. If the S5 computer is not reading a signal somewhere It will not run. Or if you still have an S4 MOP on there.
Old Apr 20, 2008 | 08:27 AM
RETed's Avatar
Pay someone or a shop who is competent to do the work.
-Ted
Old Apr 20, 2008 | 11:25 AM
OH
the car seems to flood b4 it can fire, i took spark plugs out , pulled the EGI fuse (one that shuts off the fuel pump and cranked it a few times to get the gas out and soon as i put the plugs back in i got one good ignite but only one time then it flooded out again ... imma check compression today to see how that is , hopefully thats not the problem ...
is it true that if the AFM is not working it wont , it wont spark? friend locally who has a t2 jdm told me that ???
Old Apr 20, 2008 | 01:03 PM
nevermind the electrical part of my car ... the front rotor has NO compression so a rebuild is in my immediate future .
Old May 1, 2008 | 01:15 AM
well turned out to be low compression engine so i dropped in another and YIPPEEEE it fired right up ... but still dies if i dont keep it at 2k rpm or feather the gas pedal??? any reason this is doing this? i have a whole spare engine for parts but i would like to know what would cause this
please somebody with over 1 years exp. with turbo rotories please give any advice! thanks
Old May 5, 2008 | 05:23 PM
ok im really stumped now ANYONE I DONT CARE WHO PLEASE HELP!!!
Old May 5, 2008 | 11:00 PM
Nevermind i am a god apparently , cause i fixed it! lol was a simple hidden vacuum leak in the inlet tube betweed the AFM and Turbo inlet . lol
and i found other small things i didnt see b4 but nothing to major
cristoDathird
28
May 30, 2019 08:47 PM
Kyo
Apr 13, 2019 09:24 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
