Car is not redlining
Old Apr 17, 2008 | 12:57 AM
Pnoidrummer's Avatar
i think it's the belts. i'm not too sure. i've tightened one of the belts that was actually pretty loose to spec, but iono if that really does anything. belts are in good condition. i don't htink it's the clutch, cause it pulls pretty hard up til 5 rpms, then it stays there and doesn't go any higher and i hear high squeeking noise. i'm assuming its from the engine bay
Old Apr 17, 2008 | 01:43 AM
RotaryRocket88's Avatar
Top Down, Boost Up
The belts won't stop the car from getting over 5k, but they might be slipping under load to cause the squeaking you hear.
Free-rev the car in neutral to see if it only happens when under load. Check for plugged cats too.
Old Apr 17, 2008 | 06:38 AM
farberio's Avatar
NASA-MW ST4
If you have a n/a it could be stuck aux (5/6) ports, take them out and clean them.
Old Apr 17, 2008 | 07:38 AM
DRFT_HRD's Avatar
Your Mother Is A Lizard
or just wire them open like a man.
Old Apr 17, 2008 | 11:42 AM
texFCturboII's Avatar
version 2.0
wow, neither the belts or the clutch are going to cause you to stop from redlining.
It's most likely the TPS (see Throttle Positioning Sensor) gone bad, or out of calibration.
Old Apr 17, 2008 | 11:44 AM
so if i redline in neutral and it still only gets up to around 5 rpms to 6 and stays there what does taht mean? couldn't that also be belts slipping? gah... aren't the aux ports hard to get too?
Old Apr 17, 2008 | 11:50 AM
TPS? so i have to replace it? or can i position it myself haha. yeah no idea what i'm doing lol. im' here to learn, and fix things on my own
Old Apr 17, 2008 | 12:18 PM
version 2.0
Well think about it: what turns the belts?
The engine. So, the belts have absolutely ZERO effect on the engines ability to redline. (With the obvious exception of the alternator belt, w/ no electricity you get no engine power.) What happens when it gets up to 5000 rpms? Does it stutter, or just act like that is as high as it goes? I said TPS because another member on here had a similar problem, and after a long long search that is what it was. It's not hard to fix, it's just a couple of screws.
It would be nice to know more about your car however, is it a turbo II? If so, then you can ignore these guys talking about the 5th and 6th ports cause they are only on N/A's. In fact, just go ahead and ignore them anyway because like the belts, the 5th and 6th ports have ZERO.....NONE....NO effect on the ability to redline. All they do is open up and let more air in for more power up high.
Download the FSM (see Factory Service Manual) from RX7city.com, look in there for exact instructions on doing ANYTHING to your car; then search search search away on this forum! Welcome to the wide world of cars.
Old Apr 17, 2008 | 01:30 PM
SpeedOfLife's Avatar
rotors excite me
Have you checked your timing? TPS comes strongly to my mind, too, but if you can't free rev to redline it may be something else.
Old Apr 17, 2008 | 05:21 PM
OriginalEmanresu's Avatar
300zx Driver
Im a little new to rotaries, having just been working on one for about 2 weeks now, but IMHO, I think you might have a problem with your secondary injectors. The secondary injectors, at least on the NA ive been working with, not too sure about TIIs, only operate at high RPM to provide supplemental fuel the primaries cant feed efficiently, so if your secondary injectors had gone out, you would be starving for fuel about 4.5k, especially under any kind of load. The squeeling you describe might be your fuel pump straining, or a product of the engine leaning itself as it starves for fuel. Its not your belts, they have 0 effect on engine operation, they are engine dependant, and there is no way they are so tight theyve locked your engine.
Old Apr 17, 2008 | 06:52 PM
Will_s's Avatar
Seems like everytime somebody posts this problem it turns out to be a bad ground.
Old Apr 18, 2008 | 12:37 AM
hmm... well i have a 89' n/a. i belive when i free rev it doesn't reach redline. i don't know what it reaches too. if it's TPS it's just the throttle positioning that's on top of the intake manifold?
Old Apr 18, 2008 | 01:44 AM
1st7's Avatar
no more 7
Does your tach work ???.....i mean how do you not know what it reaches.
Old Apr 18, 2008 | 08:38 AM
bikeboy23332's Avatar
look dude u need 2 find someone to check ur axuliry ports fuel ingectors possibly ur exaust. check the ingectors though mine did the same thing and my ingectors where loose and letting air in. do it
Old Apr 22, 2008 | 01:43 AM
haha. i think i'll mess with the tps first.
dkwasherexd
May 27, 2017 04:51 AM
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
Turblown
Aug 14, 2015 04:48 PM
