broken tap in trans x member hole
Old Apr 16, 2008 | 02:20 AM
initial D is REAL!'s Avatar
I got my car almost 2 years ago. After working on the car I noticeed 1 of the 4 transmission x member holes has a broken tap stuck in it. Anyone have any good ideas to fix it?
Old Apr 16, 2008 | 08:49 AM
Aaron Cake's Avatar
Engine, Not Motor
You can try a very hard drill bit and lots of cutting oil. But taps are harder then just about anything.
Sometimes you can get a punch onto one of the flutes and tap it backwards out of the hole but this won't work if it's rusted in place.
Some machine shops have an EDM stud/bolt extractor which can vaporize it.
Otherwise, you will need to cut out the captured nut from the car and then just weld in a new one.
Old Apr 16, 2008 | 01:26 PM
EDM stud extractor hugh? I'll search around for that.
My best idea was to use this special lil hole saw my friend has. It doesnt use a center drill, and comes in sizes like 5/8, 9/16 n stuff. It cuts pretty good. I was thinking of putting ina weld nut(i think that is what they are called) It looks a little like a golfing tee that you can weld in.
Sobr609
20B Forum
Feb 11, 2019 03:19 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
