Microtech lm1 with lt10s
Old Apr 15, 2008 | 08:39 PM
zeaone's Avatar
lm1 with lt10s
So the question could i use blue/red wire from lt10 with yellow wire on lm1
Old Apr 28, 2008 | 05:43 PM
petree_777's Avatar
you can wire it up but if your lt10 is not set up for a wide band o2 sensor then you are going to have to set the lm1 to output a narrow band signal
Old Apr 29, 2008 | 12:37 AM
rx72c's Avatar
Top Answer: 1
Which will be useless anyway.
Old Apr 29, 2008 | 07:45 AM
zeaone's Avatar
Rx72 is correct just wanted to know if is possiable
Old Apr 29, 2008 | 08:27 AM
BluRR's Avatar
Anybody successfully used their lc-1 or Lm-1 on the MT ecus with the narrow band setup to give a wideband reading?
Old May 22, 2008 | 10:42 PM
1sgen's Avatar
583 rwhp 1st gen
how can somebody find out if the lt10 is setup for a wide band or not?
Old May 23, 2008 | 03:37 AM
rx72c's Avatar
Top Answer: 1
of course its possible. just gives you a bogus reading. not worth the effort.
As for checking if its programmed for wideband.
That i havnt had to do so wouldnt know.
APEXL8T
Power FC Forum
Dec 15, 2006 05:06 PM
Fatty_FC3S
Wolf 3D
Jul 3, 2006 06:54 AM
hugo20
Aug 28, 2005 08:11 PM
RotorJoe
Jun 8, 2004 01:05 PM
