Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D Need a map for a stock 13B-RE.
Old Apr 9, 2008 | 04:33 AM
evileagle's Avatar
Reverse Cerberus
Anyone got a decent map for a V500 that will run a stock 13B-RE?
I'll just be running the stock twins in parallel, but other than that and an FMIC it will be factory. Just need something to get it running and build a map off of.
Thanks!
Old Apr 9, 2008 | 04:36 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
I dont have one, however if i was in your boat id probably find a FD fuel and ignition map and start there
What are you running for coils? does the v500 support the stock trailing ignitor?
Old Apr 10, 2008 | 12:46 AM
evileagle's Avatar
Reverse Cerberus
Engine-wise the 13B-RE is actually a lot closer to the 13B-T than the 13B-REW. You can actually run one on a stock Turbo II ECU. I was thinking about just using one of those maps to get started.
Old Apr 10, 2008 | 10:09 AM
coxxoc's Avatar
Shooting for 500
I think your best option is to use a plug in S5 map and go from there. I think the S5 turbo only flowed about 20 cfm. If the cosmo twins do much more there may need to be a lot of adjustments on the fuel side in boost, but S5 timing should start it. S5 timing started my 13bre, but it was street ported with 850 primaries so fuel was way off.
C. Ludwig
Jan 30, 2019 06:31 AM
Skeese
65
Mar 28, 2017 03:30 PM
Microtech
30
Apr 23, 2016 06:37 PM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
