Midwest RX-7 Forum Serving KY, IN, IL, MO, MI, WI, IA, MN, ND, SD, NE, KS
Eau Claire Wi Help
Old Feb 29, 2008 | 07:39 PM
yetterben's Avatar
7less for now!
Eau Claire Wi Help
TRying to time my 12a for boost after i locked dizzy car runs like ****. I have never played with a dizzy before and need expert help over here. Anyone in my neck of the woods??????? PM ME!!!!!!!
Old Mar 1, 2008 | 07:47 AM
moremazda's Avatar
Gone Race'n
How did you lock the weights??
Did you line up the timing mark on the pulley and the timing pin on the front cover when you re-stabbed the distributor?
Do you have a timing light? (just being sure)
Do you have the vacuum diaphragms disconnected?
Do you have additional timing marks on the main pulley?
Old Mar 1, 2008 | 10:57 AM
yetterben's Avatar
7less for now!
yes timining light but i cant get it to idle yet. it runs but like ***. re alighned everything. my ? is since its locked to i have to srop it in a diffrent tooth setting because its locked or not. which was is advanceing and which is retarding when you turn. i line it to tdc and point rotor at L1 and center it on the adjustment slot all i can do is get it to run half ***
Old Mar 1, 2008 | 12:06 PM
moremazda's Avatar
Gone Race'n
Have you marked out timing notches on the main pulley or are you using the stock marks?
Old Mar 1, 2008 | 03:34 PM
yetterben's Avatar
7less for now!
Stock marks for now i got it running pretty good gonna go throw the t light on it. I need info on tuneing this thing in i have allready upped the secondaries to 200. This is on a nikki! afm is comeing monday i need to know what afr to shoot for!
whizzybang
Naturally Aspirated Performance Forum
21
Feb 10, 2017 12:08 PM
Haro2488
Sep 8, 2015 03:18 PM
Mopagan
Jul 30, 2015 10:00 AM
MirageStarz91
Midwest RX-7 Forum
Feb 7, 2013 10:05 AM
yetterben
Midwest RX-7 Forum
Nov 19, 2007 06:45 PM
