hks tt help on 87 t2 part 2
Old Apr 18, 2002 | 04:27 PM
gsracer's Avatar
EIT
okay so I connected the e brake wire, and the tach wire, and just needed to connect the speedo wire....well I thought I knew which wire it was - green with red stripe but after hooking it up I couldn't get my speed on the turbo timer, logically I assume first I have the wrong wire(which sucks because I taped the 2 wires together all the way down and basically made everything pretty) I have a bad connection, or I'm just an idiot and can't work a turbo timer (hey the instructions were in japanese ) just looking for confirmation of the speedo wire
Old Apr 18, 2002 | 04:49 PM
NZConvertible's Avatar
I'm a boost creep...
The FC's speedo is mechanical, not electronic. AFAIK there is no speed input to the ECU. You might get it to work with the speed signal to the cruise control, but I wouldn’t put money on it.
Old Apr 18, 2002 | 07:42 PM
MtnRacer's Avatar
infini guru
Yup, I have an HKS TT installed too, but no speedometer reading, I don't think it would be worth the trouble to try and jury rig a system for it either. BUT, if you figure it out, post how you did it It'd make for an interesting read...
Steve
Old Apr 18, 2002 | 07:55 PM
cymfc3s's Avatar
I Raise Chickens
wont work. Its designed to work for a system like the FD with an electronic speed sensor.
Old Apr 18, 2002 | 10:40 PM
gsracer's Avatar
EIT
well I'm dissapointed but happy because I was rationalizing with myself why I shouldn't take all teh wiring apart and untape everything so its ok thanks for the replies guys now does anyone have any instructions on the turbo timer in english? I was flipping through the turbo timer and saw my rpms but after about 10 seconds it goes to my peak rpm screen
Old Oct 6, 2002 | 02:29 PM
chris_stampe's Avatar
I found some crappy instructions in english, and Im still having the same problem, but the instructions say to hook it up to the cruise control unit. green/red wire. There must be an electric speed sensor for the cruise, right?
Old Oct 6, 2002 | 02:32 PM
Dave-ROR's Avatar
Not sure about the RX7, but my conquest has a mechanical gauge and it still has a VSS. My HKS TT works fine and displays speed on that car, maybe I'll hook it up to the rx7 some year..
Old Oct 7, 2002 | 03:02 AM
There's a signal from the speedo to the cruise control computer, which is indeed a green wire with a red stripe. It may not be the right kind of signal, but you might get lucky. Hook it up and see what happens.
Old Mar 27, 2003 | 11:47 PM
gsracer's Avatar
EIT
Back from the dead
hahahahah!!! I had fun with my FSM and went for the G/R wire. I unhooked the plug for the cruise control harness down by the drivers side kickpanel. cut the G/R wire, soldered it in, and bam! I have a speedo reading. BWHAHAHA!!! Now I can use all those useless timer functions. Too bad I just cracked my second differential mount and my rear shocks are blown lol.
Old Mar 27, 2003 | 11:58 PM
dr0x's Avatar
pei > caek
I used the harness for mine, and if I lift my TT above the key ignition switch the TT dies. Odd
Old Mar 28, 2003 | 12:32 AM
Ryde _Or_Die's Avatar
I never found my e-brake wire. I took apart the e-brake handle and stuff, is there an easier place to find it? Like maybe under the dash or something?
Old Mar 28, 2003 | 12:39 AM
gsracer's Avatar
EIT
I'm sure I can find a diagram of where it goes in the FSM...
Does the e-brake sensor light up on your dummy lights when you pull itup?
Old Mar 28, 2003 | 12:51 AM
Ya it lights up. I took apart the damn plastic piece around the e-brake and never even got it to snap back together right Would be nice if I got the feature to work though. Any help would be great. TIA.
Old Mar 28, 2003 | 12:55 AM
dr0x's Avatar
pei > caek
I found *a* wire coming off the ebrake. Didnt see any others in the area (its under that center black piece where the mirrior switch is, under carpet) so I tied into that.
Old Mar 28, 2003 | 01:13 AM
gsracer's Avatar
EIT
exactly. Take off your center console, and unfold the carpet and it should be there.
Snoopy FD
Dec 8, 2015 01:45 PM
