Are all 86-91 rear brake calipers the same?
Old Apr 17, 2002 | 10:18 PM
rxhevin's Avatar
Are all 86-91 rear brake calipers the same? Even the ones that use the wider vented hubs? They look very much alike to me. I am just assuming that the vented must open wider? Please let me know if there is a size or manufacturer difference.
Old Apr 17, 2002 | 10:28 PM
Mykl's Avatar
hmm..
Well, some have four piston fronts, some have single piston fronts. I think all RX-7's came with ventilated disks all around.
The four lug model brakes were also different, I think.
Old Apr 17, 2002 | 10:43 PM
Mykl's Avatar
Oh shoot, sorry I misread the title. I didn't read the word "rear". :p
I think they're all the same, with the possible exception of the four lug versus five lug brakes.
Old Apr 17, 2002 | 10:53 PM
tmak26b's Avatar
the rotors are different, the calipers SHOULD be the same according to the shop manual, but mazdatrix list different parts
Old Apr 17, 2002 | 10:57 PM
rxhevin's Avatar
let me explain further to help get an answer. I plan to do the 4 to 5 lug / 4 piston(front) caliper swap. Right now I have solid rear disks. The rears that I am swaping are vented (several mm wider). I would like to reuse the current rear calipers if they are the same. Someone must know. Nasically is there ANY difference in REAR calipers from 86-91 ALL MODELS (gxl,Turbo,se,etc...)?????
Old Apr 17, 2002 | 11:21 PM
Mykl's Avatar
Run a couple searches, there should be some documentation on the 4 to 5 lug conversion. I'd help you more, but I've never had a 4 lug car so I never needed to know how to do it.
Old Apr 17, 2002 | 11:28 PM
rxhevin's Avatar
thanks Mykl, I ran a few searches and couldnt find any results that confirm or deny. I am sure someone on the forum must have the skinny on Mazdas rear calipers. I can't imagine that they made them all the same, but you never know......?
Old Apr 17, 2002 | 11:41 PM
Mykl's Avatar
Well, if nobody helps you in this thread start one along the lines of "four to five lug conversion". If somebody tells you to run a search, or gives you ****, just tell them to stick it in their pooper and that you couldn't find anything.
It's a topic that used to be on the board a lot, but I haven't seen it come up in a while.
Old Apr 17, 2002 | 11:56 PM
Yah i was wondering about this same topic !! On that same note does anyone know if its possible to just slap the four-piston brakes on the front while keeping the 4-bolt setup ?? Just wondering if so ill just get some nice 4-lug wheels...
Old Apr 18, 2002 | 08:09 AM
rxhevin's Avatar
Fuzzi, I dont think it is possible to all 4 piston fronts to the stock 4 lug rtors.
Someone on this forum must know if all 86-91 rear calipers are the same?.........Hello?
Old Apr 18, 2002 | 08:41 AM
tmak26b's Avatar
go check mazda's part #
Frisky Arab
13
Aug 18, 2015 05:30 PM
Marty RE
Aug 17, 2015 09:36 AM
Marty RE
Aug 13, 2015 11:19 AM
