12.7 in a Lsx
Old Dec 28, 2007 | 12:11 PM
5.6inmyS14's Avatar
12.7 in a Lsx
i have to scan them, hehe
but
12.7 @111mph
no traction, no diff, street tires.
Old Dec 28, 2007 | 12:28 PM
RETed's Avatar
What is an "Lsx"?
-Ted
Old Dec 28, 2007 | 12:31 PM
aram's Avatar
I think he means a GEN III Chevrolet Small block of some kind. Was this at Sacramento or infineon (sears point)? Must have been hard without a differential..
Old Dec 28, 2007 | 07:30 PM
hurleysurf24's Avatar
wtf rotary wtf
ls1
ls7
etc
Old Dec 29, 2007 | 01:04 PM
CyborgRyu's Avatar
Drift FC
Why is it X? Does he not know what kind of motor he has?
Old Dec 29, 2007 | 01:12 PM
lt1rx798's Avatar
yeah, usually "lsx" denotes the ls series engines in general, but when you are only talking about one in particular, the actual number is used.
...so is it an ls1,ls2,ls3,ls6,ls7,ls9..unlikely, or and ls truck motor?
nice time though, for a stock motor.
im alittle confused. his screen name denotes a nissan 5.6l
Old Dec 29, 2007 | 01:49 PM
rotarymandan's Avatar
packin' heat
I believe the LSx is a block that is compatible with pretty much all of the LS series parts... so you can throw on an LS6 crank, then some LS3 heads etc...
http://www.gmhightechperformance.com...ock/index.html
Old Dec 29, 2007 | 01:53 PM
NTIMD8's Avatar
http://pprod.gmgoodwrench.gmgssm.com...6454&engCat=ls
But yes, many use LSX to describe the LS series of engines, LS1, LS2, LS6 etc....
http://www.leftlanenews.com/gm-trade...gine-name.html
Old Dec 29, 2007 | 01:56 PM
5.6inmyS14's Avatar
should of made that more clear
02 ss camaro ls1
90 rx7, gtu
6spd
na diff
17x8 mustang gt rims, w/fuzion street tires
no tune
redline set to 6k when it should be 6900
1st run, 13.0
2nd run, 12.7
3rd run, blew diff
this was at sears point.
my screen name is the project im working on now, that is a 1995 nissan 240sx with a nissan armada 5.6 engine. lost my old id. baylsxrx7
Old Dec 30, 2007 | 03:56 AM
RETed's Avatar
And I thought those NA diffs were stronger than that...
-Ted
Old Dec 30, 2007 | 06:58 AM
jesse_fc3's Avatar
brum BRUM... pow
you thought N/A diffs were strong? I've heard of people blow'n them with a stock T2 engine after a swap. I'm surprised he got two runs at the track with a N/A diff powered by a LS1.
Old Jul 26, 2008 | 07:45 AM
eddierotary's Avatar
back with rotaries
they hold some power as long you dont abuse them. i ran my car with a n/a diff for a while and i was doing 300hp and i never blew it
Old Jul 26, 2008 | 01:13 PM
overkill-lt1's Avatar
its the torque not the horsepower that breaks the diffs.a rotary will not produce 250 plus ft lbs of torque at 2000 rpm and up.thats what breaks the diffs
torque is= how hard you hit the wall
hp is= how high up the wall you go
Old Jul 26, 2008 | 05:34 PM
sharingan 19's Avatar
Rotary Revolutionary
Sarcasm is apparently a lost art these days...
Old Jul 27, 2008 | 03:28 PM
5.6inmyS14's Avatar
I ran the 12.7 at Infineon. it was a good day for testing.
GM did brand the name LSX as an aftermarket LS1 swap.
I have sold the car since.
On to the S14 with a titan motor.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
BUSTN
V-8 Powered RX-7's
Oct 23, 2015 05:59 PM
Josepi
Microtech
May 16, 2003 07:48 PM
