Turbo help or ? Turbonetics 62-1?
Old Dec 14, 2007 | 11:46 AM
fceeyah's Avatar
Smile Turbo help or ? Turbonetics 62-1?
Just wondering on this turbo - Turbonetics 62-1 Turbo T4 .70 A/R Exhaust housing P-Trim? Its going on my 87 turbo 2 with haltech and other supporting mods just wondering how much boost I can run and how much horsepower? As a daily driver and track time? Is this turbo recommended for this car? If not what other turbos do you recommend please let me know before buying? And also how much would you pay for one of these?
Old Dec 14, 2007 | 12:25 PM
Turblown's Avatar
Turn up the boost
Turbine a/r is too small to be matched to that compressor. However its easy to swap housings. You can run 20+psi on it efficiently, however it will do over 2 bar. Turbonetics turbos are generally overpriced compared to Garrett units, I think those retail for $1600 in the BB version...
Old Dec 14, 2007 | 12:38 PM
RETed's Avatar
Boost is limited by fuel octane, ignition advance, and intake charge temps...
-Ted
Old Dec 14, 2007 | 02:54 PM
fceeyah's Avatar
So what is recommended for my set up just trying to acheive 350-450 horsepower daily driver? Garret turbo ?
Old Dec 14, 2007 | 05:38 PM
fastrotaries's Avatar
W. TX chirpin Monkey
I'v seen people with that compressor wheel reach your goals...all day long. However they were sporting a .96 to a 1.15 A/R on P-trim turbines. Hope that helps.
Old Dec 14, 2007 | 06:41 PM
fritts's Avatar
Mad Man
What kind of power have people hit at 20#'s? I have one but was trying to get a T04R instead as I plan to run E85. My 62-1 may work better than I thought.
Old Dec 15, 2007 | 01:06 AM
RETed's Avatar
It's at the upper limits if you're trying to hit 450 at the wheels with a 62-1.
I don't think it'll hit it with pump gas.
That's almost always race gas territory.
-Ted
Old Dec 15, 2007 | 11:34 AM
Busted7's Avatar
Will work for horsepower
I run the turbo your talking about and at 20 lbs on pump but im 8.5 to 1 comp. It makes about 460 whp.. I say about becouse dynos vary quite a lot. But on a dyno pac it made 420 whp at 16 lbs. Go with the .96 ar full spool ported at about 3800 rpms. I run 10.80's at 2740 lbs 1/4 mile!
Old Dec 16, 2007 | 10:39 PM
kenn_chan's Avatar
Savanna Rx-7
Busted, is yours a .70 hotside like the OP was looking into, or is it a .84/.96/1.05 like most people have?
the compressor is good for that range, but the hotside he listed is quite small, his is apt to end up with elevated egt's and some serious preturbine back pressure, which will limit him in a lot of ways.
kenn
just re-read the op post and realized that he probably mistook the compressor a/r when he said .70 ........
kenn
Old Dec 17, 2007 | 09:28 AM
Busted7's Avatar
Im running the .96 hot side.
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
82streetracer
Aug 23, 2015 09:28 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
