What are the differnces from turbo to non turbo?
Old Nov 23, 2007 | 03:43 PM
Guy_with_car's Avatar
Hey guy's ive got an 1987 fc and im just wondering how much of a differnces the na is from the turbo model. and wondering if it' would be allright to run light boost on the na motor?
Old Nov 23, 2007 | 04:10 PM
need RX7's Avatar
Listen to King Diamond.
there are lots of differences. the biggest one is the fact that the turbo model...has a turbo, but i'm sure you knew that already. also, the Turbo motor has 4 intake ports, whereas the NA motor has the 4 main ports plus 2 auxiliary ports that open at higher RPM to let in more air and fuel (not sure of the exact RPM). it is not that hard to swap a turbo motor into an NA chassis, and it is also possible but less popular to turbocharge an NA motor (Aaron Cake has a great write-up on this subject on this forum. Though he added a huge high boost turbo, it proves it is indeed possible to turbocharge an NA motor) you will soon learn that Aaron Cake is the ultimate master of all things rotary.
yeah you probably could have searched to find the answers to all your questions, but i'm bored and felt like answering questions
Old Nov 23, 2007 | 05:44 PM
MarcFC3S's Avatar
i love my 88 rx7
ok but wat is different on the turbo wat u would have to change on the na rx7
like are the motor mounts different???
or differential????
like wounder if u got a single turbo swap wat would i need to change or have to get????
Old Nov 23, 2007 | 05:55 PM
thebigbluecan's Avatar
SEARCH BUTTON
Old Nov 23, 2007 | 06:38 PM
Evil Aviator's Avatar
Rotorhead
See the FAQ for this section.
Old Nov 23, 2007 | 06:46 PM
Slow Rotor's Avatar
FC3S
The turbo ones also come with the 4 piston front brakes
Old Nov 23, 2007 | 07:45 PM
MarcFC3S's Avatar
i love my 88 rx7
sup man u think u could help me by answering a couple of questions
like i need a new engine and i had a non turbo engine in my rx7 but i want to do a swap and i could get like a complete 13b-t engine with tranny and all the accessories to make it run imported from japan but i have questions like are the motor mounts different on it i dont think so but i just want to be sure????????
and later on i wanna put front mount intercooler for it and i want to noe if i could up grade things on the 13b-t(turbo)
and also could u tell me if there are any other things i would have to be needed to do the swap cuz i want to do the swap fast cuz i want to drive it asap??????
i would appreciate if u helped me???
Old Nov 23, 2007 | 07:54 PM
dial8's Avatar
Registered User
No the motor mounts are the same for FC, but the diff and tranny mounts are a little different. If you want to swap into your NA I would get the series specific engine and drop it in so you don't have to worry about wiring, custom drive shafts, and other "problems" that occur when quickly swapping motors.
This takes a little work to fit behind an S4 bumper, and tons of cutting regardless. Don't do it unless you have plenty of time, a large turbo, and supporting mods.
i want to noe(know) if i could upgrade things on the 13b-t and could u tell me if there are any other things i would have to be needed to do the swap cuz i want to do the swap fast cuz i want to drive it asap??????
That should help. If you just want to drive it though, get another NA and you should have it running in an afternoon if you're careful. Swaps just require a bit of time, finesse, and attention to detail, but FC are one chassis so everything is drop in. Good luck.
Old Nov 23, 2007 | 07:58 PM
Jpk3200's Avatar
Jpk3200
http://aaroncake.net/RX-7/naturbo.htm
Old Nov 23, 2007 | 08:01 PM
MarcFC3S's Avatar
i love my 88 rx7
so if mines an 1988 n/a rx7 i have to get an 88 rx7 turbo motor right?????
cuz it come with the tranny if same year they should fit right???in on everything
if not wat would i have to do to make it fit in????????
sorry about all these questions but i really want to no more before i do this swap
Old Nov 23, 2007 | 08:16 PM
n1ko's Avatar
try searching. many people have asked the same questions as you.
your engine choice should be fine (and make for an easier swap) if you stick with the same series. 86-88 models are s4, and 89-91 models are s5. you have an s4.
Old Nov 23, 2007 | 08:23 PM
dial8's Avatar
Registered User
Thats right but unless you buy the whole Tii drive line you'll need a custom drive shaft to use it. It bolts right up to the NA transmission and you'll have no worries if you just want to get the car running.
Questions and answers are what the forums for, but searching will yield you better reulst quicker, and you'll get to see what worked and didn't work for others. Good luck
Old Nov 23, 2007 | 08:26 PM
Slow Rotor's Avatar
FC3S
I know alot of people say this, but you may as well sell your non turbo and buy one that is an actual turbo, will prolly end up costing similar and you get all the benefits of having one that came out as a turbo to begin with.
Old Nov 23, 2007 | 08:50 PM
dial8's Avatar
Registered User
Or if you have TIME and MONEY, follow Aarons lead and leave bought Tiis in the dust.
Old Nov 23, 2007 | 09:10 PM
1st7's Avatar
no more 7
so do NA GXLs
Old Nov 24, 2007 | 02:02 AM
MarcFC3S's Avatar
i love my 88 rx7
so i could just get the hole 13b-t swap and take the tranny off the T2 swap and leave my na tranny in and put the T2 motor in and it will work??????
by the ways wats so different on the t2 drive line????and are u talking about the drive shaft and differential?????
Old Nov 24, 2007 | 02:18 AM
KhanArtisT's Avatar
Former FC enthusiast
The turbo IIs have acceleration, the NA's dont. Simple as that.
Old Nov 24, 2007 | 02:23 AM
MarcFC3S's Avatar
i love my 88 rx7
is it really that much difference????
cuz i have an na and doing a swap for T2?
oh and by the way could u convert the top mount intercooler whats stock on the
T2's to front mount intercooler???
Old Nov 24, 2007 | 03:45 AM
RETed's Avatar
You really should get a test ride in a real Turbo II.
It will really open your eyes up.
-Ted
Old Nov 24, 2007 | 09:22 AM
Aaron Cake's Avatar
Engine, Not Motor
Quoted directly from the FAQ:
Can I swap a Turbo engine/Jspec engine/13BT/etc into my Non Turbo?
Yes, check these links:
https://www.rx7club.com/forum/showth...threadid=26647
http://www.rotaryresurrection.com/ro...conversion.htm
What Turbo kits can I add onto my non turbo RX-7?
There are no longer kits formally made at the time of this post, however there are companies from time to time that do make available non turbo to Turbo Kits. Because most of these companies stop building the kits, or go out of business in short time, it is impossible to keep active links for them.
Most people that turbo a non turbo make their own kits:
Using the stock TII turbo, exhaust manifold with spacer, NA intakes and NA ECU:
http://www.aaroncake.net/rx-7/naturbo.htm
https://www.rx7club.com/forum/showth...threadid=88540
https://www.rx7club.com/forum/showth...threadid=88758
https://www.rx7club.com/forum/showth...hreadid=124232
http://users2.ev1.net/~ccoutts/turbo..._a_project.htm
Using the stock TII turbo, exhaust manifold, intakes, ECU:
http://forum.teamfc3s.org/showthread.php?t=37694
Turbo-NA Forum:
http://www.aaroncake.net/forum/forum...urbocharged+NA
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
FD7KiD
Aug 17, 2015 11:50 PM
