12A race engine wiring
Old Nov 23, 2007 | 03:06 PM
pat57woods's Avatar
I've completed the install of my 12a into My 71 MG Midget, now I need to wire it up. This is basically a track car but this is my 1st rotary so I'm use to having 1 wire come out of the distrobuter...not 4, ( 5 if you include the condenser. I figure since there are 2 coils it basically the same wiring done twice). Can anyone tell me what goes where?
This is my guess...Black wires go to their own coils - side. But from there I'm stumpped.
Old Nov 23, 2007 | 03:20 PM
trochoid's Avatar
Old Fart Young at Heart
In my sig line is a link to the online FSMs which incude the wiring diagrams. Download the 85 Edition, that should show you everything you need. Iirc, the condensor is for radio static, I don't believe you need it, unless you're installing a 79 points style ignition.
Old Nov 23, 2007 | 03:24 PM
REVHED's Avatar
Hunting Skylines
It's pretty simple. You wire 12V ign to the coils, ignitors and condensor. Then you just run the negative side of each coil to it's respective ignitor. There are wiring diagrams available on the net.
Old Nov 24, 2007 | 10:48 AM
pat57woods's Avatar
12a race engine wiring
does the picture look correct?
Old Nov 24, 2007 | 08:27 PM
Spyride's Avatar
Super Cres at best
that pic is weak sauce. look into the faq page here, there you will see something about DLISDLIF or something along that line. and it should also talk about using a 2nd gen coil in that some paragraph. so look that up. thereis a link for jeff20b, he has a great write up and a much better diagram.
Old Nov 24, 2007 | 08:30 PM
Spyride's Avatar
Super Cres at best
http://www.geocities.com/cd23c/dlidfis.html
ding, thats the one
Old Nov 24, 2007 | 08:45 PM
Siraniko's Avatar
RX for fun
wrong. there are 2 coils= leading and trailing.
if you have the stock wire coming out of the igniters, the thick black with yellow or white strip goes to the coils positive terminal while the other thin wire connects to the negative side. (leading igniter faces the front; trailing faces the alternator).
Then find a wire an ignition wire (voltage with the key ON) from the MG's stock harness. Connect this to the coil's + terminal.
Old Nov 24, 2007 | 10:56 PM
pat57woods's Avatar
Thanks Wacky racer
Luckily I do have the wires on the ingniters so I should be able to figure this out. Actually the MG has no harness...strickly race car. Should be under 1,000 pounds by now.
Old Nov 24, 2007 | 11:16 PM
Siraniko's Avatar
RX for fun
then thats even easier. Run a relay to run both coils. Must be fun replacing the spark plugs since a MG has a small engine compartment.
Old Nov 24, 2007 | 11:50 PM
Jeff20B's Avatar
Lapping = Fapping
The spark plugs are easy to access in my rotarded MG Midget. Just gotta reach above or around the steering shaft.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
rx7brandon
Aug 16, 2015 10:55 AM
