turbo for na...
Old Nov 19, 2007 | 07:09 PM
creynolds_rx7's Avatar
turbo for na...
is it possible to turbo an na motor? if so is it cheaper to buy from jdm or buy all the parts separtly? what all would be needed?
Old Nov 19, 2007 | 07:13 PM
fc3sdrifterz's Avatar
it would be way cheaper jus to by a 13b-t rather then turboed a NA
Old Nov 19, 2007 | 07:15 PM
CyberPitz's Avatar
Boost ahoy!
Can I swap a Turbo engine/Jspec engine/13BT/etc into my Non Turbo?
Yes, check these links:
https://www.rx7club.com/forum/showthr...threadid=26647
http://www.rotaryresurrection.com/ro...conversion.htm
What Turbo kits can I add onto my non turbo RX-7?
There are no longer kits formally made at the time of this post, however there are companies from time to time that do make available non turbo to Turbo Kits. Because most of these companies stop building the kits, or go out of business in short time, it is impossible to keep active links for them.
Most people that turbo a non turbo make their own kits:
Using the stock TII turbo, exhaust manifold with spacer, NA intakes and NA ECU:
http://www.aaroncake.net/rx-7/naturbo.htm
https://www.rx7club.com/forum/showthr...threadid=88540
https://www.rx7club.com/forum/showthr...threadid=88758
https://www.rx7club.com/forum/showthr...hreadid=124232
http://users2.ev1.net/~ccoutts/turbo..._a_project.htm
Using the stock TII turbo, exhaust manifold, intakes, ECU:
http://forum.teamfc3s.org/showthread.php?t=37694
Turbo-NA Forum:
http://www.aaroncake.net/forum/forum...boc harged+NA
Straight from
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/frequently-asked-questions-2nd-generation-rx-7-faq-fc-494667/
Old Nov 19, 2007 | 07:18 PM
Aaron Cake's Avatar
Engine, Not Motor
This thread is being closed because this topic is either covered in the FAQ or has been covered many times before. It is suggested that you make use of the search feature and read the FAQ to find your answer. If you still cannot find what you are looking for, then feel free to post your question indicating that you have already looked for an answer, and someone will probably be happy to help.
Please be aware that this forum has been around for quite a while, and almost every common question has been covered many times in the past. It is very common for new members to ask several common questions, all of which have been answered in the FAQ for many years.
Standard online forum etiquette says that before you ask a question, you should first check the FAQ and search for you answer. This is not only polite, but often the quickest way to find the information you are looking for (as well as learn a bunch of new stuff!).
Some of the questions covered in the FAQ include:
-NA to Turbo conversions
-Electrical problems
-Stereo wiring
-Wheel sizes
-Stock HP and torque specs for all models
-Common abbreviations
-Common electrical problems
-Mileage, storage, winter driving
-much, much more
The 2nd Gen Forum also keeps an Archive of popular and informative posts. You can access this archive by using the links at the top of this forum.
Helpful links:
-FAQ: https://www.rx7club.com/forum/showthread.php?t=494667
-Search: https://www.rx7club.com/forum/search.php
-Archives: https://www.rx7club.com/forum/forumdisplay.php?f=72
Thank you,
The Moderators
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
FD7KiD
Aug 17, 2015 11:50 PM
