Apexi 3Bar Map sensor
Old Oct 18, 2007 | 12:39 PM
signofinfinity's Avatar
Coyote
Question Apexi 3Bar Map sensor
Hey all,
Asked this in a thread but was off topic there.... no responses....
Can anyone shed some light on the Apexi 3 Bar Map sensor??? I have been pointed that it might be better off then the GM unit. Is it the same sensor that the AVCR Boost Controller uses to read MAP? The small round plastic tot with the brass nipple facing downward?
Would you suggest to wire this in to read MAP or no?
Thanks all
Best,
George
Old Oct 18, 2007 | 02:31 PM
mono4lamar's Avatar
In the burnout box...
I have this map sensor on my fd. It requires no splicing of anything. Truly plug and play. Just go into FC-Edit and use PIM scale offset option 1.
Old Oct 18, 2007 | 11:53 PM
Coyote
hmmmm you mean you don't use a GM unit?
I run a wolf Plug N Play... I have the option as all ecus to select the external mat sensor. is the Apexi 1 good to go? If i splice that one in is it OK to use as a map sensor? Would you recommend it as much as the GM???
i have no specs of the Apexi map sensor and have no idea who uses it... what is the boost threshold on it? is it 3 bar effectively? when does it stop creating voltage??
Thanks for your time
G
Coyote
ps..... it is the one with the AVCR unit right????
Thanks
G
Old Oct 19, 2007 | 04:28 AM
jeroentje.nl's Avatar
I have the same sensor.. but not installed yet.
Apexi 420-A004
449-X002
it is the same sensor as with the ACV-R boost controller
From the Apexi list it is a 2.5 BAR sensor
Old Oct 19, 2007 | 07:47 AM
Coyote
^ so mean the avcr is only good to 2.4bar? no more?
G
Old Oct 22, 2007 | 02:55 AM
Coyote
Bump^ AVCR is only good for 2.5 bar due to map sensor??
G
Old Oct 22, 2007 | 07:33 AM
PBK7's Avatar
+1 on this question. I need to get one ASAP
Old Oct 26, 2007 | 06:45 AM
Coyote
....ok so if i test it.... i should get a voltage output right?
if i apply gradual pressure all the way up to three bar i should get a linear voltage scale.... makes sense? see where it stops that is at 4.5 volts and see what's the pressure.
right?
Old Oct 27, 2007 | 12:08 AM
PBK7's Avatar
Old Oct 27, 2007 | 01:30 AM
PandazRx-7's Avatar
Fast + Reliable = $$$$$
Guys, I don't understand... why not just get the GM sensor with the plug and splice 3 freakin' wires.
It's available everywhere, been around for years and proven/used by hundreds of people. Just my 2 cents.
Here's one for under $65 with plug...
http://cgi.ebay.com/ebaymotors/GM-3-...spagenameZWDVW
Old Oct 27, 2007 | 02:58 AM
Coyote
I have one sitting here..... ready to install, but if the apexi is better then i would go with that.....
I ask mainly to check if the avcr is limited to 2.5 bar boost.... see what i mean???
that mean no 28 psi pulls......or your boost will go hayyyyywire.....boom
thats why i need to know now
Thanks for the link but. it cheaper then i found around ...
G
Old Oct 28, 2007 | 12:04 AM
PandazRx-7's Avatar
G
Dude, I'm not questioning WHY you want to know... I'm just trying to say that it seems like most folks here don't use the Apexi map sensor and I personally wouldn't even bother with something that I'm getting a hard time getting info on when a proven one (GM) I KNOW works 100% with many folks at 28psi... Besides, how much better can a sensor be.
Just trying to help.
Old Oct 29, 2007 | 03:34 PM
skir2222's Avatar
I win
I am going to have to say if there was a problem with the GM sensor someone would probally say something, I know a lot of people are using it including me. It does it's job.
Old Oct 30, 2007 | 07:50 AM
PBK7's Avatar
so i can assume then its easily compatible with the powerFC?
Old Nov 6, 2007 | 03:51 AM
maxcooper's Avatar
WWFSMD
The GM sensor is compatible with the PowerFC. There are a lot of threads on here about how to wire it and what PFC settings to use.
-Max
Old Nov 6, 2007 | 05:50 AM
BlueTII's Avatar
Banzai Racing
Or you just get one of our GM 3 bar plug and play adapters and don't have to cut your engine harness.
http://www.banzai-racing.com/product...er_harness.htm
Old Nov 8, 2007 | 11:25 AM
Coyote
^^^yep! thanks Chris... will email soon
Old Nov 8, 2007 | 12:52 PM
PBK7's Avatar
Banzai, no harm in givn a price !
Old Nov 9, 2007 | 01:50 PM
topaz's Avatar
Greek Geek
Me too!
Exactly as said.
mulcryant
Sep 9, 2015 05:24 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
befarrer
Sep 4, 2015 08:26 PM
